Sonarr version (exact version): 5.0.0.2907
OS: Windows 11 Pro
Debug logs:PrivateBin
1st, I have a 75% chance of getting a Failed to load Queue error when doing any action or even just when the Queue auto refreshes
2nd, Periodicly I will go and do a Blacklist and Search on a page of files that have not downloaded in a while. When I do this the queue page auto-refreshes far more often during the search than it did with v4. When combined with the 1st problem this makes it damn near unuseable to try to do anything with the queue.
There should be some improvements in this area in the next release making it more stable while you’re making changes.
If the refresh fails while there are items the existing items should be shown instead of showing an error as well, which hopefully helps with the errors you’re seeing.
If you still have queue errors, some more information from dev tools in your browser would be helpful, including what errors you’re getting from the backend.
I linked my logs. Not a programmer myself, but if you can tell me what information you want me to pull I will do so. (Browser is Firefox)
The logs didn’t show any failures, but the dev tools might (F12 on Windows/Chrome in most browsers), the Network tab or Console will be the ones with the useful information (if requests are failing and not just being cancelled).
It’s behaving much better after the refresh changes in the latest update. Not experiencing any issues currently; thanks for the fast response
Awesome, thanks for reporting and testing some more!
