Sonarr version (exact version): 5.0.0.2668
OS: Windows 10 19045.7807
Debug logs: Will provide if needed
Description of issue: I am using v4 and decided to install v5 on another PC. On first run of v5, sonarr asks for a username and password, instead of providing the first run authentication setup. I uninstalled v5, made sure C:\ProgramData\Sonarr had been deleted and installed v5 again. It still wanted a username and password. After uninstalling v5 again, I deleted all folders named sonarr in C:\, cleaned my registry and cleared localhost password from browser password manager. I installed v5 again, but it still asks for a username and password. I shut it down, changed config.xml to <AuthenticationRequired>DisabledForLocalAddresses</AuthenticationRequired> and gained access to sonarr. I see it has a username called sonarr and a masked password.
Changing config.xml to
<AuthenticationMethod>None</AuthenticationMethod> did not get the authentication setup to appear. Sonarr changed this back to
<AuthenticationMethod>Forms</AuthenticationMethod> on shutdown/restart.
I can’t see that this would be a bug as it would have been caught in testing. What am I doing wrong? Thanks.
