Sonarr version (exact version): 4.0.0.539
Mono version (if Sonarr is not running on Windows): no idea (bash: mono: command not found)
OS: Unraid
2023-06-21 15:36:18.8|Info|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: SignalR was challenged.
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/localization/language: 200.OK (9 ms)
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/tag: 200.OK (9 ms)
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/language: 200.OK (11 ms)
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/customFilter: 200.OK (16 ms)
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/localization: 200.OK (41 ms)
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/qualityprofile: 200.OK (33 ms)
2023-06-21 15:36:21.6|Debug|Api|[GET] /api/v3/config/ui: 200.OK (18 ms)
2023-06-21 15:36:21.7|Debug|Api|[GET] /api/v3/importlist: 200.OK (40 ms)
2023-06-21 15:36:21.7|Debug|Api|[GET] /api/v3/system/status: 200.OK (60 ms)
2023-06-21 15:36:23.7|Fatal|SonarrErrorPipeline|Request Failed. GET /api/v3/series
[v4.0.0.539] System.InvalidOperationException: Sequence contains more than one matching element
at System.Linq.ThrowHelper.ThrowMoreThanOneMatchException()
at System.Linq.Enumerable.TryGetSingle[TSource](IEnumerable`1 source, Func`2 predicate, Boolean& found)
at Sonarr.Api.V3.Series.SeriesController.LinkSeriesStatistics(SeriesResource resource, SeriesStatistics seriesStatistics) in ./Sonarr.Api.V3/Series/SeriesController.cs:line 226
at Sonarr.Api.V3.Series.SeriesController.LinkSeriesStatistics(List`1 resources, List`1 seriesStatistics) in ./Sonarr.Api.V3/Series/SeriesController.cs:line 212
at Sonarr.Api.V3.Series.SeriesController.AllSeries(Nullable`1 tvdbId, Boolean includeSeasonImages) in ./Sonarr.Api.V3/Series/SeriesController.cs:line 114
at lambda_method113(Closure , Object , Object[] )
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
--- End of stack trace from previous location ---
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Sonarr.Http.Middleware.BufferingMiddleware.InvokeAsync(HttpContext context) in ./Sonarr.Http/Middleware/BufferingMiddleware.cs:line 27
at Sonarr.Http.Middleware.IfModifiedMiddleware.InvokeAsync(HttpContext context) in ./Sonarr.Http/Middleware/IfModifiedMiddleware.cs:line 40
at Sonarr.Http.Middleware.CacheHeaderMiddleware.InvokeAsync(HttpContext context) in ./Sonarr.Http/Middleware/CacheHeaderMiddleware.cs:line 32
at Sonarr.Http.Middleware.StartingUpMiddleware.InvokeAsync(HttpContext context) in ./Sonarr.Http/Middleware/StartingUpMiddleware.cs:line 37
at Sonarr.Http.Middleware.UrlBaseMiddleware.InvokeAsync(HttpContext context) in ./Sonarr.Http/Middleware/UrlBaseMiddleware.cs:line 26
at Sonarr.Http.Middleware.VersionMiddleware.InvokeAsync(HttpContext context) in ./Sonarr.Http/Middleware/VersionMiddleware.cs:line 28
at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
at Microsoft.AspNetCore.Authorization.Policy.AuthorizationMiddlewareResultHandler.HandleAsync(RequestDelegate next, HttpContext context, AuthorizationPolicy policy, PolicyAuthorizationResult authorizeResult)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware.<Invoke>g__Awaited|6_0(ExceptionHandlerMiddleware middleware, HttpContext context, Task task)
On docker using Unraid, after upgrading from v3 to v4 I can watch the logs doing the upgrades and running scan checks, but after logging into the UI it just throws an error and I can’t get into the UI whatseover. The logs above are shown immediately after a successful login, with the UI throwing the error below.
Version 4.0.0.539
something in my config/backup is causing this and i have no idea what this error is in reference to. i can load up the v4 installation fresh and work it just fine. i’ve tried taking a backup from v3 and loading restoring from the backup file in the fresh installation of v4, but there’s something there it doesn’t like. i’ve also tried copying the original v3 config folder and just pointing the v4 installation to this copied directory. both methods show logs to be upgrading the internals as needed and come to the same error after login.
