Sonarr version (exact version): 4.0.0.748 by linuxserver.io
Mono version (if Sonarr is not running on Windows): .NET
Yes (6.0.13)
OS: docker
Description of issue: how do languages work now
i have loads of series across multiple languages (like almost all of them) - i use subtitles
v3 languages were pretty simple, much like tags, you pick one and assign it to the series and youre done.
v4 i cant work out. it looks like we have to create a custom format for each language, then what? do we create multiple quality profiles of the exact same thing but with a different language in each one? because that seems like a lot of upkeep when i want to change one part of a quality profile (and now i have 30+ of them - i have three qualities, and then all languages)
could someone please explain the best way to handle languages because i havent been able to work it out yet (i only just upgraded so i might later but i presume someone will already know).
note - i cant handle dubs, the lip mismatch is way more offputting than having to read subtitles.
