Sonarr version (exact version): 3.0.1.363
Mono version (if Sonarr is not running on Windows): 5.18.0.240
OS: Synology DSM 6.2 / Docker / lsiodev/sonarr-preview
- i use cleantitle for my media, the examples on this page are wrong, the ! shouldnt be in the cleantitle version. its also not just the example text either, it impacts new series folders as they are getting the extra characters in the folder name when they shouldnt
{series cleantitleyear}, i think i understand why the year isnt in brackets, but its not really part of the title so its a bit iffy. is there a way to get a clean title, and the year in brackets? a series year token would make it possible to do any combination instead of having multiple hardcoded tokens - or is {series titleyear} a clean title with the year? its a bit hard to tell as it doesnt mention clean but it has no ! in it on the helper page (so you can understand the confusion)
if you make a change on this page without saving and go to another page you get the discard changes warning, if you click on ok you move on, but when you go back to this page your changes are still there and if you change to another page you get another discard warning even if you hadnt done anything since returning. it will even survive through F5, and shift+F5, reloads in chrome
is there a way to rename the series folders to the new format when you change it in here?
