Using tailscale to access Sonarr gives white screen
Version 4.0.16.2944:
Windows 11
I am very new to all this and have basically been using chatgpt to help me set sonarr, radarr ect up. I used tailscale on my pc with the intent to get access to sonarr ect outside of my network. Ran these commands in powershell
tailscale serve --bg --http 80 --set-path=/sonarr http://localhost:8989
tailscale serve --bg --http 80 --set-path=/radarr http://localhost:7878
tailscale serve --bg --http 80 --set-path=/prowlarr http://localhost:9696
Everything seemed to work perfectly. I accessed each site with
http://jopc.tail****.ts.net/sonarr
http://jopc.tail****.ts.net/prowlarr
http://jopc.tail****.ts.net/radarr
I got to the login screen on sonarr ect logged in then got a white screen on my phone. I had it working before without a white screen but it was only passing 1 service through at a time
Did you set the URL base in Sonarr’s General settings to match the folder you’re serving it from (/sonarr)?
