Been getting this error past day. It still works fine using Sickbeard so I know it’s not my API key.
Edited.
Edited.
Found the problem. Usernet-Crawler migrated to a new server and I needed to restart Sonarr for it to work. All is working fine now.
had the same issue, thanks for the tip @Draega
indexer unavailable again on sonarr, the “test” button successfully connects.
does anyone knows how to solve this ?
usenet-crawle http://www.usenet-crawler.com/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100 Error getting response stream (ReadDone2): ReceiveFailure
I had a few problems in my logs overnight as well. It all seems to be good now. If I had to guess i’d say teething pains with the new server on there end. Seems to be good now though.
well i did a restart of sonarr again and the error was still there but in addition to that if i click on indexer and click on test i now get a fail message.
I went to the web site and check the site api and rss hit and it was with https instead of http i had on my indexer, change it to https and now sonarr is happy again
Perfect !!! I had the same problem and is correct, I’ve changed http by https and works fine , great !!!
I’ve been having similar errors with a new setup of sonarr not connecting to Usenet-crawler. Oddly changing from https to http has fixed the problem in my case.
