Use tv list from showrss.info (torrent)
Added http://showrss.info/ as a supported import option. So that one could import from that list. I guess this would be an indexer.
Currently we only support trakt, we’re looking at adding support for anidb, but not yet.
I’m really not sure what Show RSS adds, it has RSS feeds, but I didn’t see an API when I looked quickly. Can you elaborate on why it should be added?
Not sure I’d call it an indexer, its a date provider of sorts, tend to refer to an indexer as a nzb indexer.
i would consider this a indexer, i have used this in the past, before i used sonarr. all it does is giving torrents for the shows that the users follows on the site.
Ahh, gotcha. We’re not looking at add any new indexers at this time, the next steps will be to allow for generic parsing and if this falls under that, great.
It’s just an RSS fead. So I was thinking that the same code for IPTorrents would work. But I was just thinking an import sorta of option to import the list of TV shows from one to the other.
Not likely something we’ll implement ourselves, but a 3rd party app could use the API in Sonnar and the API on Show RSS (if there is one) to sync the two.
