Upgraded from V4 to V5 quality settings can't be seen
Sonarr version (exact version): 5.0.0.2608
OS: Windows 11
Upgraded from V4 to V5. After the upgrade the Quality under settings does not show the size settings so they cannot be changed. Nothing changes if I toggle advanced
When I checked the database the V4 had min,max size etc but the V5 is missing those columns. Not sure if they have moved elsewhere
V5
V4
Size limits have moved to Quality Profiles in v5, in the latest update there is now a message indicating this.
Thanks you very much for the quick reply
