20-4-2 12:19:37.5|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.5344
That’s the only executable I see for Sonarr and that’s the v2 executable.
At this point I’d recommend grabbing a backup of the configuration, removing Sonarr/NzbDrone from Programs & Features then install Sonarr again. Start it up and restore the backup if it’s not migrated automatically (as long as you don’t remove C:\ProgramData\NzbDrone manually it should migrate).
Thx; Marcus. I did that allready. I removed Sonarr2 and I tried removing Sonarr2 and removing folders in program data.
I try to install Sonarr 3 => epic fail, therefore I have only v2 logs. I can’t import my backup, with the ongoing epic fails.
Somethings hiding I have to delete?
The Sonarr service does not start. When I start it manually it is immediately terminated.
No files found are eligible for import in D:\Newsbin\SONARR\the.daily.show.2020.04.02.bill.gates.1080p.web.x264-trump\
File is just waiting for import
D:\Newsbin\SONARR\the.daily.show.2020.04.02.bill.gates.1080p.web.x264-trump. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
Those aren’t debug logs and don’t show an import being attempted. And ControlC is overlaying content because I have an adblocker, better to use something that doesn’t do that.
Sorry, log was over 512kb limit on pastebin.
I changed my previous unrar folder in newsbin to another location and sonarr started importing files from there.
Guess sonarr had permission for that location. It works now.
