Update series keeps running, apparently stuck on family guy
Sonarr version (exact version): 2.0.0.4645
OS: Windows server 2012 r2
((Debug logs)):
I’m not seeing any errors in the log besides a missing disk.
But the update library button keeps spinning. I am also missing info for some shows, like the latest episodes, manual refresh of the show works, but if I have to do it for each and every single series manually…
I’m having the exact same issue atm,
Same Version, Same Server OS no logs :frowning:
No missing disks though.
The disk issue is a different issue.
I got a broken harddrive, so that one is unrelated
Can it have something to do with the tvdb being unavailable?
What do the ((debug logs)) show?
https://drive.google.com/open?id=0B3RLm1wWSSTIZXB0X2trM2pWUXM
https://drive.google.com/open?id=0B3RLm1wWSSTIbmhhYmUxRnNXb2s
What happens if you run ‘Test’ in Settings->Download Clients->Sabnzbd?
Edit: you should have a new category configured specifically for Sonarr. and sab sorting disabled.
I disabled the sab sorting, a dedicated category was already set up.
After restarting sonarr, it worked fine right up to family guy, now it’s hanging on that one again
Also I noticed sonarr running at a rather constant cpu load of 23%
Restarting sonarr doesn’t seem to work either, tried it a couple of times, but the process just keeps running. So I had to kill it in order to restart
I said ‘new’ for a reason, your logs indicate that sab is already reporting finished downloads that had been sorted with sab sorting, and attempts to import them. Disabling sab sorting after the fact doesn’t magically ‘fix’ those old downloads. By switching to a new category you prevent Sonarr from seeing those corrupted ones.
After that’s done, we need new trace level log files to investigate remaining issues.
