Unraid/Sonarr/NZBGet to Unraid/Sonarr/Deluge
Hello all! Noob here …
I was running Unraid/Sonarr/NZBGet but decided to move to Deluge - to take advantage of PIA VPN.
Within Sonarr I have deleted NZBGet and added Deluge. Deluge is working (as far s I can see) and passes the ‘Test’ action. I have setup the Delay Profile to be ‘Only Torrent/No Delay’.
Every time I try download an episode - I see the red ‘i’ and a rollover saying ‘Release Rejected - Usenet not enabled for this series’.
When I press the download icon - I get ‘Usenet Download client isn’t configured yet’.
Any advice GREATLY appreciated!
which version do you have?
theres an option to set downloads to be usenet only, torrent only, or prefer one or the other.
you can also do something similar via tags (so if a show is only on usenet then you can force that)
i dont remember exactly where it is but go through your config and double check for that - and for tags on that series
Thanks so much for your response, @rhom … I’m on version:
Sonarr Ver. 2.0.0.5338
I have the profile setting set to Only Torrent/No Delay’ … I don’t see anything Usenet specific in the tags … I’ve just noticed I only have a Usenet indexer … I should probably have a Torrent indexer instead?
if youve set it to torrent only, then yes, youll need a torrent indexer and torrent download client.
you should probably also disable (or delete) the usenet indexer so it doesnt uses it for searches
