Hi all,
I’m new here since few minutes. I need a help to add site which contains search engine to Indexers in Sonarr but I’m stuck.
For example:
http://nzbfriends.com/
Thanks in advance.
Patrick
That is not an indexer Sonarr supports. Sonarr supports indexers that provide the newznab API (of which there are some free ones and some donation-only ones).
Thank you Markus for your quick answer. Could you please explain to me how can I find free indexers (from below link) which are supported by Sonarr?
There is a whole section that says they are free on there… if some are no longer free then the wiki should be updated. Anything newznab or nZEDb based should work.
