Anyone figure this one out? I restarted my computer this morning and I am having the same issue.
Check out the log files to see why its failing to start.
Knowing which OS you’re using as well as Sonarr and mono (if applicable) versions is very helpful.
Hi
I have the same issue on an ongoing basis. I am running Win 10 just recently started using Sonar.
I have taken a look at the log files and got this:
15-9-21 08:55:46.3|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.3357
15-9-21 08:56:09.6|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone.Console
15-9-21 08:56:09.6|Debug|ProcessProvider| - [3408] NzbDrone.Console
15-9-21 08:56:09.6|Warn|ProcessProvider|Couldn’t get process info for NzbDrone.Console
System.ComponentModel.Win32Exception (0x80004005): Access is denied
at System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
at System.Diagnostics.NtProcessManager.GetFirstModuleInfo(Int32 processId)
at System.Diagnostics.Process.get_MainModule()
at NzbDrone.Common.Processes.ProcessProvider.GetExeFileName(Process process) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Processes\ProcessProvider.cs:line 291
at NzbDrone.Common.Processes.ProcessProvider.ConvertToProcessInfo(Process process) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Processes\ProcessProvider.cs:line 272
I am unable to end the Nzbdrone process in task manager so not sure if its sonar windows chrome my firewall or my stupidity that is preventing me from accessing the UI. (Pretty sure its the latter)
In any case any help is appreciated.
Restart your computer so the existing process terminates, until its terminated Sonarr will be unable to start a new instance.
