Sonarr version (exact version): Mono version (if Sonarr is not running on Windows): OS: ((Debug logs)): (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue: I have Sonarr’s web UI set to http://localhost:8989/. I have not made any changes, but the application will not load. The site appears to come up, with Sonarr Ver in the middle of the screen, and with the dots at the top moving to show that the app is trying to load, however, nothing does. I have tried navigating to different pages (e.g. http://localhost:8989/calendar), but it is the same experience. I am on a Mac, so have shutdown the Mac, reset the SBC (unplugged it for 30 seconds, then plugged back in and started up again), but still Sonarr is not loading. I have also followed the instructions to backup and reinstall Sonarr found at https://github.com/Sonarr/Sonarr/wiki/Backup-and-Restore, but that did not work either. The automated downloads seem to work, as while I have been working on this problem a new show was retrieved and parsed. This seems to just be a problem with the Web UI. Any help would be great.
Sorry, I am a little new to looking at the logs. In the NzbDrone folder, I have sonarr.txt, then sonarr.0.txt, .1, .2, .3, .4. Each look to be a bit different. Happy to provide whatever you need, but need a little more direction. Thanks!
Thanks. Turned on debug and here is the log. However, I noticed that this works under Chrome now, still not Firefox. Not sure what changed…I reinstalled Firefox, but no dice. At least it works…
17-10-9 23:02:31.6|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
17-10-9 23:02:32.8|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone
17-10-9 23:02:32.9|Info|MigrationLogger|*** Migrating data source=/Users/iMacHome/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Truncate;pooling=True;version=3;Full FSync=True ***
17-10-9 23:02:33.0|Debug|MigrationLogger|Took: 00:00:00.1296956
17-10-9 23:02:33.0|Info|MigrationLogger|*** Migrating data source=/Users/iMacHome/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Truncate;pooling=True;version=3;Full FSync=True ***
17-10-9 23:02:33.0|Debug|MigrationLogger|Took: 00:00:00.0119243
17-10-9 23:02:33.0|Info|Router|Application mode: Interactive
17-10-9 23:02:33.0|Debug|Router|Console selected
17-10-9 23:02:33.0|Info|OwinHostController|Listening on the following URLs:
17-10-9 23:02:33.0|Info|OwinHostController| http://*:8989/
17-10-9 23:02:33.1|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
17-10-9 23:02:33.1|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
17-10-9 23:02:33.1|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
17-10-9 23:02:33.1|Info|NancyBootstrapper|Starting Web Server
17-10-9 23:02:33.2|Debug|QualityDefinitionService|Setting up default quality config
17-10-9 23:02:33.3|Debug|NotificationFactory|Initializing Providers. Count 20
17-10-9 23:02:33.4|Debug|IndexerFactory|Initializing Providers. Count 12
17-10-9 23:02:33.4|Debug|MetadataFactory|Initializing Providers. Count 4
17-10-9 23:02:33.4|Debug|DownloadClientFactory|Initializing Providers. Count 15
17-10-9 23:02:33.6|Debug|TransmissionProxy|Transmission authentication succeeded.
17-10-9 23:02:34.0|Debug|BrowserService|non-interactive runtime. Won’t attempt to open browser.
17-10-9 23:02:34.1|Debug|SabnzbdProxy|Url: http://localhost:8080/api?mode=get_config&apikey=(removed)&output=json
17-10-9 23:02:34.2|Debug|MonoVersionCheck|Mono version is 3.10 or better: 4.2.1
17-10-9 23:02:41.0|Debug|Api|[GET] /api/config/ui: 200.OK (7 ms)
17-10-9 23:02:41.1|Debug|Api|[GET] /api/system/status: 200.OK (10 ms)
17-10-9 23:02:41.1|Debug|Api|[GET] /api/profile: 200.OK (8 ms)
17-10-9 23:02:41.1|Debug|Api|[GET] /api/queue?sort_by=timeleft&order=asc: 200.OK (12 ms)
17-10-9 23:02:41.1|Debug|Api|[GET] /api/health: 200.OK (3 ms)
17-10-9 23:02:41.3|Debug|Api|[GET] /api/series: 200.OK (199 ms)
There are (see below), but Chrome shows the same error and still loads. Let me know if there is a specific location in Firefox dev tools you would like to know about.
Nope, just standard Firefox for Mac. Here is a screenshot. I have never really run commands on the browser, though - not overtly - usually I just use utilities for that type of work. Maybe I am doing something incorrectly?
Figured it out. Had to go to the Storage tab, find the entry for Local Storage, and manually delete. After that, site loaded fine. Thanks for all your help!
