Sonarr version (exact version): 3.0.6.1196
OS: Docker
Description of issue: Sonarr unable to connect to indexer or NZBGet. Working to set up Docker containers, and while they seem to be running on their own ok, I can’t seem to get them talking to each other, or (in the case of NZBGet alone) able to resolve external server addresses. I’m definitely a bit new at Docker configurations, and would appreciate any tips on where to explore first. I’m hoping this is a broader networking issue in Docker configuration which might resolve all of my issues when fixed. Below is a snippet from the Sonarr log file which may give some clues?
Appreciate any tips!
21-6-19 10:40:23.6|Info|RssSyncService|Starting RSS Sync
21-6-19 10:40:23.8|Warn|FetchAndParseRssService|No available indexers. check your configuration.
21-6-19 10:40:23.8|Info|DownloadDecisionMaker|No results found
21-6-19 10:40:23.8|Info|RssSyncService|RSS Sync Completed. Reports found: 0, Reports grabbed: 0
21-6-19 10:55:26.0|Info|RssSyncService|Starting RSS Sync
21-6-19 10:55:26.0|Warn|FetchAndParseRssService|No available indexers. check your configuration.
21-6-19 10:55:26.0|Info|DownloadDecisionMaker|No results found
21-6-19 10:55:26.0|Info|RssSyncService|RSS Sync Completed. Reports found: 0, Reports grabbed: 0
21-6-19 11:07:54.2|Warn|Torznab|Unable to connect to indexer
[v3.0.6.1196] System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure: 'http://192.168.1.220:9696/7/api?t=caps&apikey=(removed) —> System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure
at System.Net.WebResponseStream.InitReadAsync (System.Threading.CancellationToken cancellationToken) [0x000f3] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebOperation.Run () [0x001d9] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x00094] in <91935ad653254a93b9d73a9f8f2f7a2d>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <91935ad653254a93b9d73a9f8f2f7a2d>:0 at System.Net.HttpWebRequest.GetResponse () [0x00016] in <91935ad653254a93b9d73a9f8f2f7a2d>:0 at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x00123] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:81 --- End of inner exception stack trace --- at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x001bb] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:107 at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookieContainer) [0x00086] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:126 at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00008] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:59 at NzbDrone.Common.Http.HttpClient.Get (NzbDrone.Common.Http.HttpRequest request) [0x00007] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:281 at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.FetchCapabilities (NzbDrone.Core.Indexers.Newznab.NewznabSettings indexerSettings) [0x000a1] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:64 at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider+<>c__DisplayClass4_0.<GetCapabilities>b__0 () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:36 at NzbDrone.Common.Cache.Cached1[T].Get (System.String key, System.Func1[TResult] function, System.Nullable1[T] lifeTime) [0x000b1] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Cache\Cached.cs:104
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.GetCapabilities (NzbDrone.Core.Indexers.Newznab.NewznabSettings indexerSettings) [0x00020] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:36
at NzbDrone.Core.Indexers.Torznab.Torznab.get_PageSize () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Torznab\Torznab.cs:23
at NzbDrone.Core.Indexers.Torznab.Torznab.GetRequestGenerator () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Torznab\Torznab.cs:27
at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].TestConnection () [0x00007] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:335
21-6-19 11:07:54.2|Warn|SonarrErrorPipeline|Invalid request Validation failed:
– : Unable to connect to indexer, check the log for more details
