Mono version (if Sonarr is not running on Windows): 4.2.3
OS: Ubuntu Server 16.04
Debug logs: https://pastebin.com/2fmSPykj
Description of issue: I am having trouble adding an indexer to a new Sonarr installation. This is my first time using it. I was able to add all my existing series and configure my download client. However, when I went to setup an indexer with HDBits, it fails testing and produces the provided error. Not sure where to go from here, all the pre-reqs should be installed. I am able to access the URL in the error message with curl via command line.
Failed to establish secure https connection to 'https://hdbits.org/api/torrents', libcurl fallback might be unavailable.
Two options:
- Get libcurl working
- Upgrade to mono 5.0+
Upgrading is probably the best solution as 4.2.3 is quite old at this point.
Thanks, upgrading Mono solved the issue.
