UI not loading, hangs at initial screen
Sonarr version (exact version): 2.0.0.4472
OS: Windows Server 2008 R2
((Debug logs)):https://hastebin.com/adisacowas.tex
Description of issue: I was proceeding to add something, but the UI appears but hangs. I have the gray screen with the dots going left to right and Sonarr Ver. in the middle, but nothing else happens. I have attached the log. It seems there is a ratings problem on a particular show, but I don’t know which one. Thoughts?
Looks like the DB is corrupt, namely the ratings column in the Series table. Restoring from backup would be the easiest way to resolve this, otherwise you can look directly at the database (SQLite) and either reset the ratings there or fix the affected series.
Thank you kindly! I went ahead with the backup as there was just one made before the issues started and all is well. I might mess with the database later if it acts up again.
