OS: Raspian
I am trying to define a twitter connect in Sonarr.
I built my App in twitter with the following settings:
APP permission: Read, write and Direct message
Type of APP: Native APP
APP Info:
Callback url: https://radarr.video/
Website URL: https://radarr.video/
Then I generated the comsumer keys and the ACcess token keys
In Sonarr I defined the twitter connect with all the fields set
but when I click on Connect to twitter it report failed (but no message).
In log I can see the message:
2022-09-06 11:45:33.8|Warn|HttpClient|HTTP Error - Res: [GET] https://api.twitter.com/oauth/request_token: 403.Forbidden (203 bytes)
2022-09-06 11:45:33.8|Fatal|SonarrErrorPipeline|Request Failed. POST /api/v3/notification/action/startOAuth
[v3.0.9.1549] NzbDrone.Common.Http.HttpException: HTTP request failed: [403:Forbidden] [GET] at [https://api.twitter.com/oauth/request_token]
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00154] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:105
at NzbDrone.Common.Http.HttpClient.Get (NzbDrone.Common.Http.HttpRequest request) [0x00007] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:281
at NzbDrone.Core.Notifications.Twitter.TwitterService.OAuthQuery (NzbDrone.Common.OAuth.OAuthRequest oAuthRequest) [0x00025] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Notifications\Twitter\TwitterService.cs:38
at NzbDrone.Core.Notifications.Twitter.TwitterService.GetOAuthRedirect (System.String consumerKey, System.String consumerSecret, System.String callbackUrl) [0x00014] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Notifications\Twitter\TwitterService.cs:62
at NzbDrone.Core.Notifications.Twitter.Twitter.RequestAction (System.String action, System.Collections.Generic.IDictionary2[TKey,TValue] query) [0x00055] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Notifications\Twitter\Twitter.cs:63 at NzbDrone.Core.ThingiProvider.ProviderFactory
2[TProvider,TProviderDefinition].RequestAction (TProviderDefinition definition, System.String action, System.Collections.Generic.IDictionary2[TKey,TValue] query) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\ThingiProvider\ProviderFactory.cs:86 at Sonarr.Api.V3.ProviderModuleBase
3[TProviderResource,TProvider,TProviderDefinition].RequestAction (System.String action, TProviderResource providerResource) [0x000e5] in M:\BuildAgent\work\63739567f01dbcc2\src\Sonarr.Api.V3\ProviderModuleBase.cs:179
at Sonarr.Api.V3.ProviderModuleBase3[TProviderResource,TProvider,TProviderDefinition].<.ctor>b__2_3 (System.Object x) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\Sonarr.Api.V3\ProviderModuleBase.cs:31 at Nancy.NancyModule+<>c__DisplayClass38_0
1[T].b__0 (System.Object args) [0x00047] in :0
at Nancy.NancyModule+<>c__DisplayClass40_01[T].<Post>b__0 (System.Object args, System.Threading.CancellationToken ct) [0x00047] in <e31b230dbd29407fadcc55713e0bbd0f>:0 at Nancy.Routing.Route
1[T].Invoke (Nancy.DynamicDictionary parameters, System.Threading.CancellationToken cancellationToken) [0x00017] in :0
at Nancy.Routing.DefaultRouteInvoker.Invoke (Nancy.Routing.Route route, System.Threading.CancellationToken cancellationToken, Nancy.DynamicDictionary parameters, Nancy.NancyContext context) [0x00086] in :0
at Nancy.Routing.DefaultRequestDispatcher.Dispatch (Nancy.NancyContext context, System.Threading.CancellationToken cancellationToken) [0x002b7] in :0
at Nancy.NancyEngine.InvokeRequestLifeCycle (Nancy.NancyContext context, System.Threading.CancellationToken cancellationToken, Nancy.Bootstrapper.IPipelines pipelines) [0x0011d] in :0
Thank you for any tips
