Sonarr version: 2.0.0.5344
Windows 7 Pro
I’m trying to integrate Newsbin v6.82 (build 5142)
On the newsbin side, my settings for Remote NZB Interface are: (after I check the box to enable it)
Username: -blank-
Password: -blank-
ApI Key: -blank-
port: 8000 (which is the default)
catagories: *,movies,series,tv
On the Sonar Side: I got to Settings->Download client-> -> SABnzbd (chosen because newsbin is not listed and I saw a suggestion to use this one somewher else)
The filled in values are:
Enable: Yes
host: 127.0.0.1
port 8000 (changed from default of 8080)
URL base: -blank-
API Key: abcd (will not allow me to leave blank)
username: -blank-
password: -blank-
category: tv
Recent Priority: Default
Older Priority: default
Use SSL: No
Of course, when I click test, I’m getting a failure. As soon as I can figure out how, I will attach the log file and debug log file from sonarr. I would appreciate any help I can get.
– update
log files are at dropbox https://www.dropbox.com/sh/fvljge9wbmqq8bf/AABeVHn_Kc5qYucPcpVA_edza?dl=0
