Been trying to figure this one out for a little bit now.
I can’t seem to get releases to auto download at all, when I click on the missing episode and click automatic search it finds the episode and downloads it no problem. There are always valid releases and my indexer & torrent client seems to be working properly. It just doesn’t happen automatically anymore.
I keep seeing these mesages in my sonarr logs.
Indexer KickassTorrents rss sync didn't cover the period between 9/8/2015 1:52:06 AM and 9/14/2015 1:47:24 PM UTC. Search may be required.
If Sonarr is unable to find RSS results over a period of time it will log that, either because Sonarr hasn’t been running or the RSS interval is too long.
KAT has made a change that prevents Sonarr from automatically grabbing torrents, we’re looking into it.
One thing I’ve noticed about kat.cr lately is that the initial upload of a torrent reports 0 seeds and 0 leeches for several hours after uploading. Is it possible that while it’s in the RSS feed, since the numbers are showing as zero, it doesn’t see it as a valid download source and skips it, and once the numbers are there, it’s no longer on the RSS feed, so it doesn’t go back and pull them unless you tell it to.
The development updates the past 2 days, there hasn’t been updates since September 3rd
2.0.0.3472 - Sep 23 2015 develop Install Latest
Fixed Consistent display of sizes
2.0.0.3471 - Sep 22 2015 develop Installed
Fixed Missing Episode Search command wasn’t stored properly in the db causing it to search for all series, instead of one.
2.0.0.3469 - Sep 21 2015 develop
New Custom Script Download contains SourcePath and SourceFolder
New Custom Script environment variables use underscores instead of periods
New Only show completed downloads in queue when Completed Download Handling is enabled
Fixed Removing torcache url query params to avoid redirect.
Fixed Parse TVRip releases as SDTV
Fixed Parsing 4-digit season packs
Fixed Log error message when moving file to recycling bin fails
Fixed Extremely long series titles causing display issues on main page
