Torrents Added to wrong directory
Mono version (if Sonarr is not running on Windows):5.10.1.47
OS: Ubuntu Server 18.04
Debug logs: https://pastebin.com/1HMCCxGw
Description of issue: Torrents are found and added through sonarr to qBittorrent-nox v4.0.3. The torrents are successfully added but do not download. They are set to download and acknowledge peers and seeds. If I add the torrent file manually or copy the magnet link from the torrent added by sonarr it downloads normally.
I noticed torrents added by sonarr aren’t sent to the directory set in series settings. Eg. the series will say /media/HDD/Downloads/TV/Series but in qbittorrent its set to /media/HDD/Downloads.
Any ideas?
Sonarr doesn’t do anything that should prevent qbit from downloading, does qbit give any indication why it’s not downloading?
They never are, Sonarr will import them after they download.
qbit doesn’t give any indication that there is a problem. The torrent sits idle, force resume or force check do not help, nor does stopping and starting. Is it possible the problem is on qbits end?
Seems likely to me, no idea what it could be though.
qBit guys suggested updating to the newest release, but the issue persists. Anyone got any other ideas?
