Version: 2.0.0.5338
Mono Version: 5.20.1
When I try to add a new series I get a timeout as shown here in the log file:
[v2.0.0.5338] System.Net.WebException: The operation has timed out.: 'http://skyhook.sonarr.tv/v1/tvdb/shows/en/361753' ---> System.Net.WebException: The operation has timed out.
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000e8] in /build/mono/src/mono/mcs/class/System/System.Net/HttpWebRequest.cs:956
at System.Net.HttpWebRequest.GetResponse () [0x0000f] in /build/mono/src/mono/mcs/class/System/System.Net/HttpWebRequest.cs:1218
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0011b] in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:82
When I put the address into a browser it times out as well. If I instead use https instead of http it works just fine. Is this something I can change in my setup? I didn’t see anything obvious.
thanks
