Mono version (if Sonarr is not running on Windows): QMono v5.12.0.266
OS: QNAP Firmware v4.3.5.0728 (Build 20181013)
Debug logs: https://pastebin.com/PsmCivtv
One TV series has been having an issue where for some reason new files are being saved in the location /share/media/video/tv/[series_name]/.@_thumb. Figured I’d Delete the series and re-import into Sonarr from disk. Doesn’t work. Every single time I try to re-import this particular series it adds the .@_thumb extension to the path. I’ve tried other series and do not experience this issue so it seems to be isolated to this one series. I don’t know what happened, I’d never had this problem until very recently. Would not have discovered the problem were it not for the fact that SABnzbd was telling me it was downloading the episodes but then they would never show up in Plex. Checked Sonarr and somehow the series’ default path suddenly included that thumb extension.
I’ve googled for hours about this and none of the suggestions I have come across have worked. Every time I browse to the folder and select it Sonarr adds that .@_thumb to the path. Very frustrating.
Please advise, and TIA.
