The magic number in GZip header is not correct
Sonarr version (exact version): 2.0.0.4427
OS: Server 2012R2
((Debug logs)):
http://pastebin.com/embed_iframe/qSZW289Z
Brand new installation and receiving TONS of errors regarding GZip like the below
The magic number in GZip header is not correct. Make sure you are passing in a GZip stream.
Also just had the below while adding a series…I’m lost
Error occurred while executing task RefreshSeries: The magic number in GZip header is not correct. Make sure you are passing in a GZip stream.
It looks like something is affecting the connection to our API for series data, perhaps only returning partial data.
Is the issue still persisting?
Are you able to load skyhook.sonarr.tv/v1/tvdb/shows/en/257655 in your browser?
The issue doesn’t seem to be persisting today…I rebooted server to double check this morning. When going to the address you supplied i was prompted for a download of a JSON file.
I tested import/scan/add series and the “issue” is no longer there.
Sounds like a hiccup with Cloud Flare, thanks for reporting back.
Seems to be happening again today
