Sonarr version (exact version): 2.0.0.5054
Mono version (if Sonarr is not running on Windows): 5.0.0
OS: Docker (on Ubuntu)
((Debug logs)): no logs
Description of issue: Everything is on title. My config of Telegram notification is here:
We need ((debug logs)), either of a grab or an import.
Hi!
There are logs for a grabbed episode:
$ cat sonarr_config/logs/sonarr.trace.txt | grep Notification
output
17-12-11 00:00:42.9|Trace|EventAggregator|EpisodeGrabbedEvent -> NotificationService
17-12-11 00:00:42.9|Debug|NotificationService|Notification and series have one or more matching tags.
17-12-11 00:00:43.2|Trace|EventAggregator|EpisodeGrabbedEvent <- NotificationService
Please post the full debug log from that time to an external site and link it here.
Hi!
there is a full trace log for the moment when an episode was grabbed:
17-12-18 15:54:23.0|Debug|RTorrentProxy|Executing remote method: load.raw
17-12-18 15:54:23.0|Debug|RTorrentProxy|Executing remote method: d.name
17-12-18 15:54:23.0|Info|DownloadService|Report sent to rTorrent. The Walking Dead S07E06 MULTi 720P
17-12-18 15:54:23.0|Trace|EventAggregator|Publishing EpisodeGrabbedEvent
17-12-18 15:54:23.0|Trace|EventAggregator|EpisodeGrabbedEvent -> NotificationService
17-12-18 15:54:23.0|Debug|NotificationService|Notification and series have one or more matching tags.
17-12-18 15:54:23.9|Debug|RestSharpExtensions|Validating Responses from [POST] [https://api.telegram.org/botXXXXXXXXX:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/sendmessage] status: [OK]
17-12-18 15:54:23.9|Trace|EventAggregator|EpisodeGrabbedEvent <- NotificationService
17-12-18 15:54:23.9|Trace|EventAggregator|EpisodeGrabbedEvent -> HistoryService
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- HistoryService
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent -> DownloadMonitoringService
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- DownloadMonitoringService
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent -> PendingReleaseService
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- PendingReleaseService
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent -> CutoffModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- CutoffModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent -> MissingModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- MissingModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent -> EpisodeModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- EpisodeModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent -> CalendarModule
17-12-18 15:54:24.0|Trace|EventAggregator|EpisodeGrabbedEvent <- CalendarModule
17-12-18 15:54:24.0|Trace|Http|Res: 1707 [POST] /api/release: 200.OK (1216 ms)
17-12-18 15:54:24.0|Debug|Api|[POST] /api/release: 200.OK (1216 ms)
17-12-18 15:54:28.1|Trace|Http|Req: 1708 [GET] /api/health
17-12-18 15:54:28.1|Trace|Http|Res: 1708 [GET] /api/health: 200.OK (3 ms)
17-12-18 15:54:28.1|Debug|Api|[GET] /api/health: 200.OK (3 ms)
17-12-18 15:54:28.1|Trace|Http|Req: 1709 [GET] /api/diskspace
17-12-18 15:54:28.1|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
17-12-18 15:54:28.2|Trace|Http|Res: 1709 [GET] /api/diskspace: 200.OK (86 ms)
17-12-18 15:54:28.2|Debug|Api|[GET] /api/diskspace: 200.OK (86 ms)
17-12-18 15:54:28.3|Trace|Http|Req: 1710 [GET] /api/health
17-12-18 15:54:28.3|Trace|Http|Req: 1711 [GET] /api/diskspace
17-12-18 15:54:28.3|Trace|Http|Res: 1710 [GET] /api/health: 200.OK (2 ms)
17-12-18 15:54:28.3|Debug|Api|[GET] /api/health: 200.OK (2 ms)
17-12-18 15:54:28.3|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
17-12-18 15:54:28.4|Trace|Http|Res: 1711 [GET] /api/diskspace: 200.OK (88 ms)
17-12-18 15:54:28.4|Debug|Api|[GET] /api/diskspace: 200.OK (88 ms)
17-12-18 15:54:29.0|Trace|CommandQueueManager|Publishing CheckForFinishedDownload
17-12-18 15:54:29.4|Trace|CommandQueueManager|Checking if command is queued or started: CheckForFinishedDownload
17-12-18 15:54:29.4|Trace|CommandQueueManager|Inserting new command: CheckForFinishedDownload
I hope is usefull to you to help me
Next time please post the logs else where and link them here.
Sonarr sent the notification and Telegram responded with a successful response. I also tested grab notifications on my end and they were successful. Is your Chat ID correct?
