Hi all, since couple days sonarr is no longer running its task. Logs are showing the follow:
Task Error: The DataMapper was unable to load the following field: ‘LastExecution’ value: ‘’. Invalid format string
Also,
Marr.Data.DataMappingException: The DataMapper was unable to load the following field: ‘LastExecution’ value: ‘’. Invalid format string —> System.FormatException: Invalid format string
at System.DateTime.ParseExact (System.String s, System.String[] formats, IFormatProvider provider, DateTimeStyles style) [0x00000] in :0
at System.Data.SQLite.SQLiteConvert.ToDateTime (System.String dateText, SQLiteDateFormats format, DateTimeKind kind, System.String formatString) [0x00000] in :0
at System.Data.SQLite.SQLiteConvert.ToDateTime (System.String dateText) [0x00000] in :0
at System.Data.SQLite.SQLiteConvert.ToDateTime (IntPtr ptr, Int32 len) [0x00000] in :0
at System.Data.SQLite.SQLite3.GetDateTime (System.Data.SQLite.SQLiteStatement stmt, Int32 index) [0x00000] in :0
at System.Data.SQLite.SQLite3.GetValue (System.Data.SQLite.SQLiteStatement stmt, SQLiteConnectionFlags flags, Int32 index, System.Data.SQLite.SQLiteType typ) [0x00000] in :0
at System.Data.SQLite.SQLiteDataReader.GetValue (Int32 i) [0x00000] in :0
at Marr.Data.Mapping.MappingHelper.LoadExistingEntity (Marr.Data.Mapping.ColumnMapCollection mappings, System.Data.Common.DbDataReader reader, System.Object ent, Boolean useAltName) [0x00000] in :0
at Marr.Data.Mapping.MappingHelper.CreateAndLoadEntity (System.Type entityType, Marr.Data.Mapping.ColumnMapCollection mappings, System.Data.Common.DbDataReader reader, Boolean useAltName) [0x00000] in :0
at Marr.Data.Mapping.MappingHelper.CreateAndLoadEntity[ScheduledTask] (Marr.Data.Mapping.ColumnMapCollection mappings, System.Data.Common.DbDataReader reader, Boolean useAltName) [0x00000] in :0
at Marr.Data.DataMapper.Query[ScheduledTask] (System.String sql, ICollection1 entityList, Boolean useAltName) [0x00000] in <filename unknown>:0 at Marr.Data.QGen.QueryBuilder
1[NzbDrone.Core.Jobs.ScheduledTask].ToList () [0x00000] in :0
at NzbDrone.Core.Datastore.BasicRepository`1[NzbDrone.Core.Jobs.ScheduledTask].All () [0x00000] in :0
at NzbDrone.Core.Jobs.TaskManager.GetPending () [0x00000] in :0
at NzbDrone.Core.Jobs.Scheduler.ExecuteCommands () [0x00000] in :0
at System.Threading.Tasks.TaskActionInvoker+ActionInvoke.Invoke (System.Threading.Tasks.Task owner, System.Object state, System.Threading.Tasks.Task context) [0x00000] in :0
at System.Threading.Tasks.Task.InnerInvoke () [0x00000] in :0
at System.Threading.Tasks.Task.ThreadStart () [0x00000] in :0
Anybody any ideas?
Its running on a Debian Linux system tho.
Greetz.
