Sonarr version 3.0.10.1567:
New CPU and I’m doing what I did in the past… but missing something I suppose.
What am I missing…
Tried Sonarr to SABNZB
And Sonarr to NZBGet.
All Test connection pass.
But when trying to download anything, I get the error:
[v3.0.10.1567] System.Xml.XmlException: ‘doctype’ is an unexpected token. The expected token is ‘DOCTYPE’. Line 1, position 4.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowUnexpectedToken(String expectedToken1, String expectedToken2)
at System.Xml.XmlTextReaderImpl.ParseDoctypeDecl()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
at NzbDrone.Core.Download.NzbValidationService.Validate(String filename, Byte[] fileContent) in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\NzbValidationService.cs:line 21
at NzbDrone.Core.Download.UsenetClientBase1.Download(RemoteEpisode remoteEpisode) in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\UsenetClientBase.cs:line 78 at NzbDrone.Core.Download.DownloadService.DownloadReport(RemoteEpisode remoteEpisode) in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\DownloadService.cs:line 75 at Sonarr.Api.V3.Indexers.ReleaseModule.DownloadRelease(ReleaseResource release) in C:\BuildAgent\work\63739567f01dbcc2\src\Sonarr.Api.V3\Indexers\ReleaseModule.cs:line 129 at Sonarr.Api.V3.Indexers.ReleaseModule.<.ctor>b__10_2(Object x) in C:\BuildAgent\work\63739567f01dbcc2\src\Sonarr.Api.V3\Indexers\ReleaseModule.cs:line 65 at Nancy.NancyModule.<>c__DisplayClass38_0
1.b__0(Object args)
at Nancy.NancyModule.<>c__DisplayClass40_01.<Post>b__0(Object args, CancellationToken ct) at Nancy.Routing.Route
1.d__7.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Nancy.Routing.DefaultRouteInvoker.d__2.MoveNext()
at Nancy.Routing.DefaultRequestDispatcher.d__5.MoveNext()
at Nancy.NancyEngine.d__22.MoveNext()
