Sonarr version (V2.0.0.5228): Mono version (5.12.0.226): OS: Readynas (Debian jessie 8.11) Debug logs: N/A (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here. Post in .txt not .doc, .rtf or some other formatted document) Description of issue: Hey all, I’m fairly new to Linux and recently bought a readynas for plex with TV shows, I currently use the windows version of Sonarr (which is a godsend btw) to download the multitude of tv shows my family and I watch, I use Jackett to get RSS feeds from TorzNab because I’ve no idea how to use usenet, I’ve got a very basic handle of linux and had sonarr running on my readynas yesterday, I decided to try to get jackett working as well, and must have messed something up because now sonarr doesn’t even run, even attempting to uninstall and reinstall mono + nzbdrone.
I saw that one before I posted here, followed his advice and still nothing, I will continue to try and if I can’t solve it I may just reformat my ReadyNAS and start over. Thanks for the hasty replies though
Okay, so I’ve got Sonarr working by removing both mono + sonarr and anything related to both and re-installing from scratch, now I can’t get the autostart script to work, on the instructions provided, the last step (before security) is " sudo service nzbdrone start " it starts the service fine, however I cannot access the webui after inputting this command (am I supposed to be able to?) and upon restarting the readynas I also cannot access the webUI, not without running sudo service nzbdrone stop and then mono --debug /opt/NzbDrone/NzbDrone.exe
I’d also like to note that when running sudo update-rc.d nzbdrone defaults I get a insserv warning of current start runlevel(s) (0 1 2 3 4 5 6) of script `nzbdrone’ overrides LSB defaults (2 3 4 5).
which leads me to believe it’s not properly reading /etc/init.d/nzbdrone, which I’ve removed and added numerous ways (via nano, vim, even SmarTTY, all of which return the same warning.
I’m glad I got it to work again and hopefully I won’t screw anything up when trying to install jackett again . Oh well, it’s a learning experience, thanks
Not sure about the init script issue, but when you start the service is Sonarr actually running? It’ll write to the logs if it is, and you should be able to see the mono task running.
Side note, if your NAS can run docker that might make life easier especially if Jackett smashed mono when it was installed.
Hm, well I’m out of ideas then, I’ve no idea why running “sudo service nzbdrone start” isn’t actually doing anything. I’ll have to try re-installing (yet again ) and hope it works, feels like insanity, many thanks for all of the help you’ve given me though, much appreciated!
EDIT: Woohoo! I finally got things working by just re-installing as admin rather than Root, I figure it had something to do with permissions and I guess I was right (I didn’t log in to root at all, only an admin account with sudo permissions)
Thank you so much Markus101, you’ve been a great help!
