OS: Arch + Docker
[v2.0.0.5344] System.InvalidOperationException: Sequence contains more than one element
at System.Linq.Enumerable.SingleOrDefault[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0007b] in <798dd06330af4ca3886d7d2be5573af7>:0
at NzbDrone.Core.Tv.SeriesRepository.FindByTitle (System.String cleanTitle) [0x0001e] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Tv\SeriesRepository.cs:33
at NzbDrone.Core.Tv.SeriesService.FindByTitle (System.String title) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Tv\SeriesService.cs:82
at NzbDrone.Core.Parser.ParsingService.GetSeries (System.String title) [0x0004b] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Parser\ParsingService.cs:56
at NzbDrone.Core.MediaFiles.EpisodeImport.Manual.ManualImportService.ProcessFolder (System.String rootFolder, System.String baseFolder, System.String downloadId) [0x00035] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\Manual\ManualImportService.cs:104
at NzbDrone.Core.MediaFiles.EpisodeImport.Manual.ManualImportService+<>c__DisplayClass15_0.<ProcessFolder>b__1 (System.String subfolder) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\Manual\ManualImportService.cs:123
at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x00051] in <798dd06330af4ca3886d7d2be5573af7>:0
at System.Linq.Enumerable+ConcatIterator`1[TSource].MoveNext () [0x0002b] in <798dd06330af4ca3886d7d2be5573af7>:0
at System.Linq.Enumerable+WhereEnumerableIterator`1[TSource].ToList () [0x00030] in <798dd06330af4ca3886d7d2be5573af7>:0
at System.Linq.Enumerable.ToList[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <798dd06330af4ca3886d7d2be5573af7>:0
at NzbDrone.Core.MediaFiles.EpisodeImport.Manual.ManualImportService.ProcessFolder (System.String rootFolder, System.String baseFolder, System.String downloadId) [0x000f9] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\Manual\ManualImportService.cs:125
at NzbDrone.Core.MediaFiles.EpisodeImport.Manual.ManualImportService.GetMediaFiles (System.String path, System.String downloadId) [0x00072] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\Manual\ManualImportService.cs:97
at NzbDrone.Api.ManualImport.ManualImportModule.GetMediaFiles () [0x001c4] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ManualImport\ManualImportModule.cs:28
at NzbDrone.Api.REST.RestModule`1[TResource].<set_GetResourceAll>b__32_0 (System.Object options) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\REST\RestModule.cs:111
at (wrapper dynamic-method) System.Object.CallSite.Target(System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object)
at Nancy.Routing.Route+<>c__DisplayClass4.<Wrap>b__3 (System.Object parameters, System.Threading.CancellationToken context) [0x00049] in <63c44d6f8d7e4f339a987bf9eb94d931>:0
I’m trying to import some episodes and am running into this issue. I think the issue is specifically with the two shows, The Haunting
and The Haunting Of
