Mono version (if Sonarr is not running on Windows): 5.18.0.240
OS: Synology
Debug logs: https://pastebin.com/zZ4rCfGH
Description of issue: I just changed my configuration putting transmission in a separate docker. Before everything was working fine and now the import are failing. The files are downloaded and put in the right folder. I can see them but the import fails again and again.
I did:
- The Remote Path Mapping
- Chmod 777
When I import manually the file in the right directory, the file become green in the calendar.
Thank you in advance for your help
