SIRRJ
March 30, 2018, 4:17am
1
It seems that permissions for Sonarr have been set wrong since updating to the newest version using the sc-download group. I’m getting errors like:
Couldn’t import episode /volume1/homes/admin/download station/downloads/[FILENAME]: Access to the path is denied.
I’ve checked the permissions in File Station and the downloads folder is owned by user sc-transmission and group sc-download.
It worked fine before, this all started since updating to the new permissions-structure.
TRaSH
March 31, 2018, 3:32pm
2
did you read the following topic ?
Your synology utilizes ACLs to add an additional security layer. That helps in not needing to fiddle around with the user:group in the *nix layer.
It took me a while to realize, the best thing is to stay away from the *nix layer, and use the ACLs what they are intended for.
In a “clean” setup, as long as the sc-download or sc-media group has been granted access in the Synology layer.
drwxrwxrwx+ 3 Me users 4096 Mar 6 07:49 Deluge
drwxrwxrwx+ 2 deluge users 4096 Mar 6 07:52 Once…
The + ind…
SIRRJ
April 2, 2018, 10:07pm
3
Thank you @TRaSH by fixing the group membership and doing chown on the download and destination folder all is operational again!!!
Greg_S
April 4, 2018, 2:37pm
4
And did you read the note about permissions when you upgraded? If was quite clearly pointed out when you were about to click ok or install…
It appears not.
RTFM or the notes when installing!
system
Closed
June 3, 2018, 2:37pm
5
