jgelon
August 8, 2024, 9:02am
1
Sonarr version (exact version) : 5.8.3.8933
Mono version (if Sonarr is not running on Windows) :
OS : docker (under linux)
Debug logs :
Description of issue :
Hi all
I was wondering if there is a new/better way to update the downloads of series via Sonarr into Synology. with the synoindex
I found Simple Synoindex Server - Syno dlna Index when in Docker - #2 by michi491 but it is already 10 years old.
fanboy
August 8, 2024, 5:19pm
2
jgelon
August 8, 2024, 7:42pm
3
I would have assumed so aswell, but when I do an error is thrown on testing the connection
fanboy
August 8, 2024, 8:55pm
4
Post logs then.
Assuming it’s probably going to come down to being a docker instance vs syno install but maybe logs will shed some light on why.
Might be worth checking if this makes any kind of difference: https://trash-guides.info/Hardlinks/How-to-setup-for/Synology/#additional-synology-info
fanboy
August 8, 2024, 9:00pm
5
And have you actually tried your original linked solution? Just because it’s old doesn’t necessarily mean it doesn’t work.
If you haven’t tried, I would recommend doing that first.
Thank you, my doubts have been answered
system
Closed
November 25, 2024, 4:55am
7
