Sonarr version (exact version): 2.0.0.5153
Mono version (if Sonarr is not running on Windows): Stable 4.8.1.0/22a39d7
OS: Ubuntu 16.04.4
Debug logs: N/A
Description of issue: The TV show Strike gets released as S01, S02, S03 for every 2-3 episodes. The TVDb listing shows all of the episodes as S01E##. How can I go about getting Sonarr to automatically pick up the new releases as they show up, so that I don’t have to manually go search for them, rename them, then import them?
It’d need to be added to the xem.de
Awesome, except that page seems to not work for me (blank page).
Seems like the page needs Flash.
(no thanks)
I found it, it’s thexem.de. I talked to the guys in IRC and they linked the two so now it works.
I noticed this and had to download the last ep manually
But did also notice that if I hover the mouse over the season 1 episode numbers, a pop up info actually has the correct season and episode numbering
