Hi everyone.
Consider this my obligatory “I love Sonarr, it’s amazing, it does everything I want it to” section, because it really does.
I’ve had this installation running nearly two years now, by my reckoning. Windows 10, stable install, has run pretty much without a hitch.
This morning, I couldn’t access the web interface. Some deduction led me to the fact that the service wasn’t running, and gave me an 1053: Couldn’t start in a reasonable time error when I tried to start it manually.
Did an install over the top of the latest version. It started up. Died again. Went into the actual folder, found that I could start it by doing a run as administrator. Got it working, went in, and went to the Updates section to update to the latest development release. That seemed to download and install ok, but wouldn’t start. Went back in, ran as administrator again, big glaring error message. Basically, I’ve been hitting the same error all the way through.
“Argument Out of Range Exception: StartIndex cannot be less than zero”
I really don’t want to have to do a clean install. At last check I have roughly 1200 series in this install, and so having to re-identify them from scratch would not be ideal.
The full commandline error message from the last time I ran the Console exe as Administrator:
[Info] Bootstrap: Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.Console.exe - Version 2.0.0.4641
[Debug] ProcessProvider: Found 1 processes with the name: NzbDrone.Console
[Debug] ProcessProvider: - [10696] NzbDrone.Console
[Debug] ProcessProvider: Found 0 processes with the name: NzbDrone
[Info] MigrationLogger: *** Migrating data source=C:\ProgramData\NzbDrone\nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] MigrationLogger: *** 108: fix_extra_file_extension migrating ***
[Debug] MigrationLogger: Beginning Transaction
[Info] fix_extra_file_extension: Starting migration to 108
[Debug] MigrationLogger: PerformDBOperation
[Debug] MigrationLogger: Performing DB Operation
[Error] MigrationLogger: System.ArgumentOutOfRangeException: StartIndex cannot be less than zero.
Parameter name: startIndex
at System.String.Substring(Int32 startIndex, Int32 length)
at NzbDrone.Core.Datastore.Migration.fix_extra_file_extension.FixExtraFileExtensionForTable(IDbConnection conn, IDbTransaction tran, String table) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\Migration\108_fix_extra_file_extension.cs:line 35
at NzbDrone.Core.Datastore.Migration.fix_extra_file_extension.FixExtraFileExtension(IDbConnection conn, IDbTransaction tran) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\Migration\108_fix_extra_file_extension.cs:line 18
at FluentMigrator.Runner.Processors.SQLite.SQLiteProcessor.Process(PerformDBOperationExpression expression) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\Processors\SQLite\SQLiteProcessor.cs:line 113
at FluentMigrator.Builders.Execute.PerformDBOperationExpression.ExecuteWith(IMigrationProcessor processor) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator\Builders\Execute\ExecuteExpressionRoot.cs:line 67
at FluentMigrator.Runner.MigrationRunner.<>c__DisplayClass72_0.<ExecuteExpressions>b__1() in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 489
at FluentMigrator.Runner.StopWatch.Time(Action action) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\StopWatch.cs:line 57
at FluentMigrator.Runner.MigrationRunner.ExecuteExpressions(ICollection`1 expressions) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 489
[v2.0.0.4641] System.ArgumentOutOfRangeException: StartIndex cannot be less than zero.
[Debug] MigrationLogger: Rolling back transaction
at FluentMigrator.Runner.MigrationRunner.ExecuteExpressions(ICollection`1 expressions) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 502
at FluentMigrator.Runner.MigrationRunner.ExecuteMigration(IMigration migration, Action`2 getExpressions) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 458
at FluentMigrator.Runner.MigrationRunner.ApplyMigrationUp(IMigrationInfo migrationInfo, Boolean useTransaction) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 308
at FluentMigrator.Runner.MigrationRunner.MigrateUp(Boolean useAutomaticTransactionManagement) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 157
at NzbDrone.Core.Datastore.Migration.Framework.MigrationController.Migrate(String connectionString, MigrationContext migrationContext) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\Migration\Framework\MigrationController.cs:line 51
at NzbDrone.Core.Datastore.DbFactory.Create(MigrationContext migrationContext) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\DbFactory.cs:line 84
at NzbDrone.Core.Datastore.DbFactory.Create(MigrationType migrationType) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\DbFactory.cs:line 56
at NzbDrone.Core.Datastore.DbFactory.RegisterDatabase(IContainer container) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\DbFactory.cs:line 36
at NzbDrone.Host.Bootstrap.Start(ApplicationModes applicationModes, StartupContext startupContext) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Host\Bootstrap.cs:line 73
at NzbDrone.Host.Bootstrap.Start(StartupContext startupContext, IUserAlert userAlert, Action`1 startCallback) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Host\Bootstrap.cs:line 40
at NzbDrone.Console.ConsoleApp.Main(String[] args) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Console\ConsoleApp.cs:line 20
