I’ve talked about this on IRC with markus101 about this issue already but i’m looking for a solution to solve this issue or a workaround.
Currently I have only torrents setup as indexers to use it as torrent only. I’m using Transmission as my downloading client. I’ve setup 3 indexers as my source: Kickass, IpTorrents and TorrentLeech.
Since i’ve starting to use the torrents version I have troubles that some torrents stall on 100%. This is due that some torrents are rar packed and have a sample mkv in the root. NZBDrone automatically stops post processing this torrents. And since NZBDrone can’t unpack the archive and post process it stays stalled on 100%
But i’m looking how I can make this work with the current torrents-only setup. Since all torrent providers (also kickass torrents) have torrents that have rars in them and the sample in the root. So each time when i’m missing a serie i have to manually correct NZBDrone and look for a torrents that’s not packed.
I could do the following: Torrent send to Transmission, Transmission downloads, Run a post-processing script that unpacks it to a custom directory, and let drone factory post process it again. Are there any other ways to fix this?
