Mono version (if Sonarr is not running on Windows): 6.12.0
OS: Docker on unRAID
2022-08-29 00:49:35,671 DEBG ‘sonarr’ stdout output:
[Fatal] SonarrErrorPipeline: Request Failed. GET /api/v3/series
[v3.0.9.1549] code = Error (1), message = System.Data.SQLite.SQLiteException (0x800007BF): SQL logic error
integer overflow
at System.Data.SQLite.SQLite3.Reset (System.Data.SQLite.SQLiteStatement stmt) [0x00088] in :0
at System.Data.SQLite.SQLite3.Step (System.Data.SQLite.SQLiteStatement stmt) [0x0006e] in :0
at System.Data.SQLite.SQLiteDataReader.Read () [0x00043] in :0
at Marr.Data.DataMapper.Query[T] (System.String sql, System.Collections.Generic.ICollection1[T] entityList, System.Boolean useAltName) [0x000a2] in M:\BuildAgent\work\63739567f01dbcc2\src\Marr.Data\DataMapper.cs:569 at Marr.Data.DataMapper.Query[T] (System.String sql, System.Collections.Generic.ICollection
1[T] entityList) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\Marr.Data\DataMapper.cs:546
at Marr.Data.DataMapper.Query[T] (System.String sql) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\Marr.Data\DataMapper.cs:537
at NzbDrone.Core.SeriesStats.SeriesStatisticsRepository.SeriesStatistics () [0x00057] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\SeriesStats\SeriesStatisticsRepository.cs:35
at NzbDrone.Core.SeriesStats.SeriesStatisticsService.SeriesStatistics () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\SeriesStats\SeriesStatisticsService.cs:23
at Sonarr.Api.V3.Series.SeriesModule.AllSeries () [0x0002f] in M:\BuildAgent\work\63739567f01dbcc2\src\Sonarr.Api.V3\Series\SeriesModule.cs:108
at Sonarr.Http.REST.RestModule1[TResource].<set_GetResourceAll>b__33_0 (System.Object options) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\Sonarr.Http\REST\RestModule.cs:124 at Nancy.NancyModule+<>c__DisplayClass14_0
1[T].b__0 (System.Object args) [0x00047] in :0
at Nancy.NancyModule+<>c__DisplayClass16_01[T].<Get>b__0 (System.Object args, System.Threading.CancellationToken ct) [0x00047] in <e31b230dbd29407fadcc55713e0bbd0f>:0 at Nancy.Routing.Route
1[T].Invoke (Nancy.DynamicDictionary parameters, System.Threading.CancellationToken cancellationToken) [0x00017] in :0
at Nancy.Routing.DefaultRouteInvoker.Invoke (Nancy.Routing.Route route, System.Threading.CancellationToken cancellationToken, Nancy.DynamicDictionary parameters, Nancy.NancyContext context) [0x00086] in :0
at Nancy.Routing.DefaultRequestDispatcher.Dispatch (Nancy.NancyContext context, System.Threading.CancellationToken cancellationToken) [0x002b7] in :0
at Nancy.NancyEngine.InvokeRequestLifeCycle (Nancy.NancyContext context, System.Threading.CancellationToken cancellationToken, Nancy.Bootstrapper.IPipelines pipelines) [0x0011d] in :0
Description of issue: When trying to connect it shows the login from, then after authentication it only displays “SQL logic error integer overflow
Version 3.0.9.1549” from the root of the web server.
I attempted to run: sqlite3 sonarr.db “.recover” | sqlite3 new.db
and copy this over. Neither db will work. After many years of use, I’m almost afraid I am overflowing some integer total.
LMK if sending the db for review is necessary. It is over 700M and the recovered one is about 650M. Both open fine in an SQLite db Browser.
