Hi All
I usually download subtitles for my series, and since subtitles are synced with specific release, I do prefer downloading only relevant releases.
I come from Sickrage and it’s pretty simple to add ‘required words’ when adding a new series, however, it get a little tricky to not-possible on Sonarr.
From what I understand, I need to add the show name as a tag for each show, then go to ‘indexes’ and set required words per tag ? (do multiple required words treated as OR ?)
Is this correct ? is there anything simpler ?
You need to add a tag to the series and the same tag to the restriction, it can be a tag of your choosing, but adding a tag of the series title on it’s own won’t do anything.
Within a single restriction it’s or (must contain at least one word) if you want and add two different restrictions.
Hi,
Thank you for replying @markus101
What I meant was to add the show title as a tag, i,e, breaking-bad
Then on the indexers page, require ‘RELEASE’ for ‘breaking-bad’ tag, and that’s should provide me the option to download specific releases per series, the question was if this is the simplest way of doing it ?
