OS:
Hello, I want to organize the series and movies using folders.
I have the hard drive properly mounted, the files are downloaded correctly to the hard drive, but they are not placed in the location I want and it does not create the folders for each series and then the folders for each season. And the name of the files does not correspond to what I put in “Media management”.
I use transmission and sonarr, but it is impossible for me to do so.
I don’t know how the “Root foders” thing works, how do I have to put it there?
And when adding a series that download folder I put ? And in transmission?
Well, my idea is that each series is saved in the media/nas/series location, and then sonarr automatically creates the series folder with that of their respective seasons. I don’t know if it’s possible.
And in transmission, then what folder do I have to put for download?
PLEASE HELP ! AND THANK YOU !
