Sonarr Wont Start (Loading Dots) Qnap
Sonarr version (exact version): (Should be latest Developer build, can’t login to check.
Mono version (if Sonarr is not running on Windows): 3.10.0-2
OS: QTS 4.2.0
I believe there was a recent update, as I can no longer enter Sonarr. When visiting the site I simply get the loading bar, and that’s it “Flowing Balls”.
I found this in the Google Chrome inspector, not sure if this means anything to you:
`{message: "database or disk is full↵database or disk is full",…}
description
"System.Data.SQLite.SQLiteException: database or disk is full↵database or disk is full↵at System.Data.SQLite.SQLite3.Reset (System.Data.SQLite.SQLiteStatement) <0x001f7>↵at System.Data.SQLite.SQLite3.Step (System.Data.SQLite.SQLiteStatement) <0x000fd>↵at System.Data.SQLite.SQLiteDataReader.NextResult () <0x00560>↵at System.Data.SQLite.SQLiteDataReader..ctor (System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior) <0x00245>↵at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteDataReader..ctor (System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior) <0x00037>↵at System.Data.SQLite.SQLiteCommand.ExecuteReader (System.Data.CommandBehavior) <0x00047>↵at System.Data.SQLite.SQLiteCommand.ExecuteDbDataReader (System.Data.CommandBehavior) <0x00013>↵at System.Data.Common.DbCommand.ExecuteReader () <0x00018>↵at (wrapper remoting-invoke-with-check) System.Data.Common.DbCommand.ExecuteReader () <0x00057>↵at Marr.Data.DataMapper.Query<NzbDrone.Core.SeriesStats.SeasonStatistics> (string,System.Collections.Generic.ICollection`1<NzbDrone.Core.SeriesStats.SeasonStatistics>,bool) <0x00103>↵at Marr.Data.DataMapper.Query<NzbDrone.Core.SeriesStats.SeasonStatistics> (string,System.Collections.Generic.ICollection`1<NzbDrone.Core.SeriesStats.SeasonStatistics>) <0x0002f>↵at Marr.Data.DataMapper.Query<NzbDrone.Core.SeriesStats.SeasonStatistics> (string) <0x0005b>↵at NzbDrone.Core.SeriesStats.SeriesStatisticsRepository.SeriesStatistics () <0x00107>↵at NzbDrone.Core.SeriesStats.SeriesStatisticsService.SeriesStatistics () <0x0001a>↵at NzbDrone.Api.Series.SeriesModule.AllSeries () <0x0001a>↵at NzbDrone.Api.REST.RestModule`1<NzbDrone.Api.Series.SeriesResource>.<set_GetResourceAll>b__c (object) <0x00020>↵at (wrapper dynamic-method) object.CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object) <0x00085>↵at Nancy.Routing.Route/<>c__DisplayClass4.<Wrap>b__3 (object,System.Threading.CancellationToken) <0x00108>↵"
message
Lemme guess… euh… maybe the ‘disk is full’, you know, as no free space left? :smiley:
But I have like 2TB of free space, that’s what I don’t understand.
My database is 22,745,088 bytes in size. Is there a limit on this?
TRACE Log: http://hastebin.com/daqevohiru.tex
2TB on the drive where the database is?
Its possible the database is corrupt in some way, make a copy somewhere then try restoring a ((backup)).
Your logs would be a lot more useful in the event of a Sonarr related error if mono was running in debug mode (--debug switch).
I have a few database backups so I’ll try to restore one.
I’m not sure exactly how to set Mono in debug mode, but I’ll do some research and see if I can figure this out.
Just to clarify, there is no size limit on the database, right?
Not that we’ve seen, currently have one at over 44MB.
Ok, so restoring a backup database didn’t work. i even tried to remove the existing database all together, and yet, it still will not load.
Do the logs show anything different when the database is removed?
Does the user running Sonarr have the proper permissions to write to the database file?
Ok, so I completely removed and reinstalled Sonarr and Mono.
Everything seems to be working again, but I cannot get my config and backup restored.
I’ve removed the newly created .db file, and replaced it with my backup, but when I restart Sonarr, it still says “It looks like you are new”
Sounds like permissions, make sure the owner is the same user that Sonarr runs as.
I am experiencing the same thing right now. The logs shows the disk space error and I can’t restore a backup database.
I’m not familiar enough with the back end QNAP (Linux) file directory to know which directories I’d need to check. Nor do I even know how to check what user is running Sonarr.
FIXED!
Turns out the version of Sonarr I had installed, vs the new one I installed, use different directories to store the DB and config.
OLD:
/share/MD0_DATA/homes/admin/.config/NzbDrone
NEW:
/share/MD0_DATA/SONARR_CONFIG
Once I put the DB back into the correct folder, it loaded all my shows again. (The DB was corrupt as you suspected, as I needed to use an older backup)
Any idea why the DB corrupts, this isn’t the first time I’ve had to restore backups or replace the DB entirely.
On OS X its because the filesystem and SQLite fail to cooperate, the file system says something has been written, but in reality it hasn’t. On other OSes it could be a number of things, sometimes bad data gets written, in some cases a bug in mono caused it. In this case it doesn’t look corrupt, but the filesystem not allowing SQLite to write the file.
Thanks for the info markus101, always a pleasure working with you :slight_smile:
