Sonarr will not start on NAS Synology
Hello,
I recently updated to DSM 6.0 however since then my sonarr app will not work.
Does anyone have any ideas?
Many thanks,
Darren
A search would have provided you everything you need.
https://forums.sonarr.tv/search?q=dsm%206
Thanks Markus101. I tried to follow some of the guides via your link and struggled to understand (I am very new to NAS Synology).
When trying to change the start up script it indicated an error E138 - which I believe is something to do with ownership. Do you have a guide to how I can tackle that?
OR will there be an update to the existing packages on Syno community which will make the packages work normally again?
Hope you can help.
Tarq
I’m not aware of a guide, I’ve never done it myself. I would hope the package gets update, though its not something we maintain.
so I have done all of the above and Sonarr was running great for a week or so win Synology’s Mono and DSM6. Then on Sunday it stopped starting.
We had a power cut which I think did some damage, when I try and start now nothing. Is there anyway to tell what’s falling over? as there are NO usable logs.
most probably the database got corrupted after the power loss. check backup-restore in the wiki
