Sonarr version (exact version): 3.0.3.899
OS: CentOS 7 (64-bit)
Debug logs: https://gofile.io/d/HWIOJu
Description of issue: I put on the trace logs, but I can’t really pinpoint where the problem is. Sonarr is definitely doing something on the backend, even if it’s insignificant but I cannot access the Web UI until I stop and restart the application (after which it only takes a couple minutes to freeze the Web UI again.)
I’ve wiped my Sonarr installation and installed it a-new, as well as deleting the database and trying to start over (still encountered a Web UI lockout.) Not exactly sure what’s going on here.
