ran command: service sonarr status
and got this:
● sonarr.service - Sonarr Daemon
Loaded: loaded (/lib/systemd/system/sonarr.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-10-13 16:57:00 UTC; 1min 13s ago
Main PID: 62011 (mono)
Tasks: 13 (limit: 38301)
Memory: 118.0M
CGroup: /system.slice/sonarr.service
└─62011 /usr/bin/mono --debug /usr/lib/sonarr/bin/Sonarr.exe -nobrowser -data=/var/lib/sonarr
Sonarr version (exact version): 3.0.9.1555
OS: Ubuntu 18.04
Description of issue: No longer able to get to Sonarr UI. Getting an error page:
This page isn’t working
xx.xx.xx.xx didn’t send any data.
ERR_EMPTY_RESPONSE
Few seconds later it refreshes and says:
Connection Refused
Update Logs
022-10-10 03:16:17.9|Info|UpdateApp|Starting Sonarr Update Client
2022-10-10 03:16:18.1|Info|AppFolderInfo|Data directory is being overridden to [/var/lib/sonarr]
2022-10-10 03:16:18.1|Debug|UpdateApp|NzbDrone process ID: 1087
2022-10-10 03:16:18.1|Debug|UpdateApp|Arguments:
2022-10-10 03:16:18.1|Debug|UpdateApp| 1087
2022-10-10 03:16:18.1|Debug|UpdateApp| /tmp/sonarr_update
2022-10-10 03:16:18.1|Debug|UpdateApp| /usr/lib/sonarr/bin/Sonarr.exe
2022-10-10 03:16:18.1|Debug|UpdateApp| /data=/var/lib/sonarr
2022-10-10 03:16:18.1|Debug|UpdateApp| /nobrowser
2022-10-10 03:16:18.1|Debug|UpdateApp|Using executing application: /usr/lib/sonarr/bin/Sonarr.exe
2022-10-10 03:16:18.1|Debug|UpdateApp|Executable location: /usr/lib/sonarr/bin/Sonarr.exe
2022-10-10 03:16:18.1|Info|InstallUpdateService|Installation Folder: /usr/lib/sonarr/bin
2022-10-10 03:16:18.1|Info|InstallUpdateService|Updating Sonarr from version 3.0.8.1507 to version 3.0.9.1549
2022-10-10 03:16:18.1|Info|InstallUpdateService|Verifying requirements before update…
2022-10-10 03:16:18.1|Debug|ProcessProvider|Finding process with Id:1087
2022-10-10 03:16:18.7|Debug|ProcessProvider|Found process 1087:mono-sgen [/usr/bin/mono-sgen]
2022-10-10 03:16:18.7|Info|InstallUpdateService|Verifying Update Folder
2022-10-10 03:16:19.3|Debug|ProcessProvider|Found 0 processes with the name: Sonarr.Console
2022-10-10 03:16:20.0|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2022-10-10 03:16:20.0|Debug|ProcessProvider| - [1087] mono-sgen
2022-10-10 03:16:20.6|Info|BackupAndRestore|Creating backup of existing installation
2022-10-10 03:16:20.6|Debug|DiskTransferService|Mirror Folder [/usr/lib/sonarr/bin] > [/tmp/sonarr_update/sonarr_backup/]
2022-10-10 03:16:20.6|Debug|DiskTransferService|Mirror Folder [/usr/lib/sonarr/bin/UI] > [/tmp/sonarr_update/sonarr_backup/UI]
2022-10-10 03:16:20.6|Debug|DiskTransferService|Mirror Folder [/usr/lib/sonarr/bin/UI/Content] > [/tmp/sonarr_update/sonarr_backup/UI/Content]
2022-10-10 03:16:20.6|Debug|DiskTransferService|Mirror Folder [/usr/lib/sonarr/bin/UI/Content/Images] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images]
2022-10-10 03:16:20.6|Debug|DiskTransferService|Mirror Folder [/usr/lib/sonarr/bin/UI/Content/Images/Icons] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons]
2022-10-10 03:16:20.6|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/favicon-32x32.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/favicon-32x32.png]
2022-10-10 03:16:20.6|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/browserconfig.xml] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/browserconfig.xml]
2022-10-10 03:16:20.7|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/favicon-debug-16x16.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/favicon-debug-16x1>2022-10-10 03:16:20.7|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/favicon.ico] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/favicon.ico]
2022-10-10 03:16:20.7|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/android-chrome-512x512.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/android-chrome->2022-10-10 03:16:20.7|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/mstile-150x150.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/mstile-150x150.png]
2022-10-10 03:16:20.7|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/apple-touch-icon.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/apple-touch-icon.png]
2022-10-10 03:16:20.8|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/mstile-310x150.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/mstile-310x150.png]
2022-10-10 03:16:20.8|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/favicon-debug-32x32.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/favicon-debug-32x3>2022-10-10 03:16:20.8|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/favicon-debug.ico] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/favicon-debug.ico]
2022-10-10 03:16:20.8|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/mstile-310x310.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/mstile-310x310.png]
2022-10-10 03:16:20.8|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/favicon-16x16.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/favicon-16x16.png]
2022-10-10 03:16:20.9|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/safari-pinned-tab.svg] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/safari-pinned-tab.sv>2022-10-10 03:16:20.9|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/mstile-144x144.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/mstile-144x144.png]
2022-10-10 03:16:20.9|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/manifest.json] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/manifest.json]
2022-10-10 03:16:20.9|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/android-chrome-192x192.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/android-chrome->2022-10-10 03:16:20.9|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/Icons/mstile-70x70.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/Icons/mstile-70x70.png]
2022-10-10 03:16:20.9|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/error.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/error.png]
2022-10-10 03:16:21.0|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/404.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/404.png]
2022-10-10 03:16:21.0|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/logo.svg] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/logo.svg]
2022-10-10 03:16:21.0|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Images/poster-dark.png] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Images/poster-dark.png]
2022-10-10 03:16:21.0|Debug|DiskTransferService|Mirror Folder [/usr/lib/sonarr/bin/UI/Content/Fonts] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Fonts]
2022-10-10 03:16:21.0|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Fonts/Roboto-Light.woff] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Fonts/Roboto-Light.woff]
2022-10-10 03:16:21.0|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Fonts/Roboto-Regular.woff] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Fonts/Roboto-Regular.woff]
2022-10-10 03:16:21.1|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Fonts/fonts.css] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Fonts/fonts.css]
2022-10-10 03:16:21.1|Debug|DiskTransferService|Copy [/usr/lib/sonarr/bin/UI/Content/Fonts/Roboto-Light.woff2] > [/tmp/sonarr_update/sonarr_backup/UI/Content/Fonts/Roboto-Light.woff2]
GNU nano 4.8 2022.10.10-03.16.txt
2022-10-10 03:16:24.5|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Api.V3.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.Api.V3.dll.mdb]
2022-10-10 03:16:24.5|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Api.V3.dll.mdb
2022-10-10 03:16:24.5|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.SignalR.dll] > [/usr/lib/sonarr/bin/Sonarr.SignalR.dll]
2022-10-10 03:16:24.5|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.SignalR.dll
2022-10-10 03:16:24.6|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Common.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.Common.dll.mdb]
2022-10-10 03:16:24.6|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Common.dll.mdb
2022-10-10 03:16:24.6|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/NLog.Targets.Syslog.dll] > [/usr/lib/sonarr/bin/NLog.Targets.Syslog.dll]
2022-10-10 03:16:24.6|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Core.dll] > [/usr/lib/sonarr/bin/Sonarr.Core.dll]
2022-10-10 03:16:24.6|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Core.dll
2022-10-10 03:16:24.6|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.SignalR.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.SignalR.dll.mdb]
2022-10-10 03:16:24.6|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.SignalR.dll.mdb
2022-10-10 03:16:24.6|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.RuntimePatches.dll] > [/usr/lib/sonarr/bin/Sonarr.RuntimePatches.dll]
2022-10-10 03:16:24.6|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.RuntimePatches.dll
2022-10-10 03:16:24.7|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Common.dll] > [/usr/lib/sonarr/bin/Sonarr.Common.dll]
2022-10-10 03:16:24.7|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Common.dll
2022-10-10 03:16:24.7|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Host.dll] > [/usr/lib/sonarr/bin/Sonarr.Host.dll]
2022-10-10 03:16:24.7|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Host.dll
2022-10-10 03:16:24.7|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/System.Reflection.TypeExtensions.dll] > [/usr/lib/sonarr/bin/System.Reflection.TypeExtensions.dll]
2022-10-10 03:16:24.7|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Mono.dll] > [/usr/lib/sonarr/bin/Sonarr.Mono.dll]
2022-10-10 03:16:24.7|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Mono.dll
2022-10-10 03:16:24.7|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/NodaTime.dll] > [/usr/lib/sonarr/bin/NodaTime.dll]
2022-10-10 03:16:24.7|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/NodaTime.dll
2022-10-10 03:16:24.8|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.RuntimePatches.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.RuntimePatches.dll.mdb]
2022-10-10 03:16:24.8|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.RuntimePatches.dll.mdb
2022-10-10 03:16:24.8|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.exe] > [/usr/lib/sonarr/bin/Sonarr.exe]
2022-10-10 03:16:24.8|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.exe
2022-10-10 03:16:24.8|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Api.dll] > [/usr/lib/sonarr/bin/Sonarr.Api.dll]
2022-10-10 03:16:24.8|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Api.dll
2022-10-10 03:16:24.8|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Api.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.Api.dll.mdb]
2022-10-10 03:16:24.8|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Api.dll.mdb
2022-10-10 03:16:24.8|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Core.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.Core.dll.mdb]
2022-10-10 03:16:24.8|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Core.dll.mdb
2022-10-10 03:16:24.8|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Http.dll] > [/usr/lib/sonarr/bin/Sonarr.Http.dll]
2022-10-10 03:16:24.8|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Http.dll
2022-10-10 03:16:24.9|Debug|DiskTransferService|Copy [/tmp/sonarr_update/Sonarr/Sonarr.Mono.dll.mdb] > [/usr/lib/sonarr/bin/Sonarr.Mono.dll.mdb]
2022-10-10 03:16:24.9|Trace|DiskProviderBase|Deleting file: /usr/lib/sonarr/bin/Sonarr.Mono.dll.mdb
2022-10-10 03:16:24.9|Info|TerminateNzbDrone|Killing all running processes
2022-10-10 03:16:25.6|Debug|ProcessProvider|Found 0 processes with the name: Sonarr.Console
2022-10-10 03:16:25.6|Debug|ProcessProvider|Found 0 processes to kill
2022-10-10 03:16:26.3|Debug|ProcessProvider|Found 0 processes with the name: Sonarr
2022-10-10 03:16:26.3|Debug|ProcessProvider|Found 0 processes to kill
2022-10-10 03:16:26.3|Info|ProcessProvider|[1087]: Killing process
2022-10-10 03:16:26.3|Info|ProcessProvider|[1087]: Waiting for exit
2022-10-10 03:16:26.3|Info|ProcessProvider|[1087]: Process terminated successfully
2022-10-10 03:16:26.3|Info|InstallUpdateService|Waiting for external auto-restart.
2022-10-10 03:16:27.4|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2022-10-10 03:16:27.4|Debug|ProcessProvider| - [641602] mono-sgen
2022-10-10 03:16:27.4|Info|InstallUpdateService|Sonarr was restarted by external process.
2022-10-10 03:16:27.5|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2022-10-10 03:16:27.5|Debug|ProcessProvider| - [641602] mono-sgen
2022-10-10 03:16:27.5|Info|UpdateApp|Update completed successfully
