Version 5.0:
**Mono version N/A:
windows 11:
N/A:
**Sonarr *v5.0.0.2635
Running the installer, it indicates it will not update the 4.x versions automatically, so I ran it manually, and it indicated “some processes are running” (or similar) And it then offers to kill the other processes off, but it doesn’t tell which processes need to be shut down. I assume those are the service accounts that automatically run Sonarr when I log in. When I choose the option to have the installer shut down the processes, it fails. So for now I’m aborting the install until I get more information. I’m not sure if this is all logged or not. If I need to, I’ll upload the log.
