Sonarr version (exact version): v4
OS: Raspberry Pi OS latest 64bit
Debug logs: Below
I had v3 running for years on my raspberry pi os. I saw there was an update so I followed instructions:
- Made a backup of sonarr v3 config
- Purged sonarr v3
sudo apt purge sonarr -y --auto-remove - Then installed sonarr v4
- v4 installed fine, I could access the web UI and saw that v4 was installed, created authentication username/password, but no config had restored, all of my tv show congig, tracker credentials, scripts were lost.
- So I attempted to restore config from the v3 backup, but that seem to have totally corrupted sonarr. Web UI is not reachable anymore. I tried restarting raspberry pi, but nothing. When I run
sudo systemctl status sonarrI get:
pi@rpi5:~ $ sudo systemctl status sonarr
ā sonarr.service - Sonarr Daemon
Loaded: loaded (/etc/systemd/system/sonarr.service; enabled; preset: enabled)
Active: active (running) since Sat 2024-11-16 01:30:38 EET; 20min ago
Main PID: 764 (Sonarr)
Tasks: 10 (limit: 4450)
CPU: 4.361s
CGroup: /system.slice/sonarr.service
āā764 /opt/Sonarr/Sonarr -nobrowser -data=/var/lib/sonarr/
Nov 16 01:30:42 rpi5 Sonarr[764]: at Microsoft.AspNetCore.Mvc.Filters.MiddlewareFilterBuilderStartupFilter.<>c__DisplayClass0_0.<Configure>g__MiddlewareFilterBuilder|0(IAp>
Nov 16 01:30:42 rpi5 Sonarr[764]: at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken)
Nov 16 01:30:42 rpi5 Sonarr[764]: at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
Nov 16 01:30:42 rpi5 Sonarr[764]: at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
Nov 16 01:30:42 rpi5 Sonarr[764]: at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
Nov 16 01:30:42 rpi5 Sonarr[764]: at NzbDrone.Host.Bootstrap.Start(String[] args, Action`1 trayCallback) in ./Sonarr.Host/Bootstrap.cs:line 80
Nov 16 01:30:42 rpi5 Sonarr[764]: at NzbDrone.Console.ConsoleApp.Main(String[] args) in ./Sonarr.Console/ConsoleApp.cs:line 45
Nov 16 01:30:42 rpi5 Sonarr[764]: Press enter to exit...
Nov 16 01:30:43 rpi5 Sonarr[764]: Non-recoverable failure, waiting for user intervention...
- Iām ok to loose all of my settings, tv show config, etc., but just PLEASE let me know how to completely remove sonarr v4 and start fresh.
