**Sonarr version 4.0.0.433
OS: unRAID
If you don’t provide any information, no one can help you.
objects that arent matched simply will not import when manually trying to import them the lower corner just says completed but does not do it
Debug logs will likely be needed. See the instructions you ignored when making your initial post.
Its Easter and had my son and hes 4 so was getting into trouble, ill grab logs next time i see it happen. just switched from prowlarr to nzbhydra 2 as i was having massive indexer issues with sonarr only (not lidarr or radarr) when using prowlarr
