Sonarr update fail and issues after - Help
Hi thereTrying to update Sonnar to the latest version and somehow got stuck and consequently I had to reinstall.
I am running Debian and using Swizzin and so when I go to install Sonarr, I get this message:
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
fatal: Unable to read current working directory: No such file or directory
INFO Installing sonarr
DOCS Further reference: Sonarr | swizzin community edition
… Downloading release archive
:heavy_check_mark: Archive downloaded
… Extracting archive
:heavy_check_mark: Archive extracted
… Installing Systemd service
:heavy_check_mark: Sonarr service installed and enabled
… Sonarr is loading…
:heavy_check_mark: Loading finished
… Configuring nginx
grep: /home/nanohits/.config/Sonarr/config.xml: No such file or directory
:heavy_check_mark: Nginx configured
SUCCESS Sonarr installed
So basically I removed Sonarr and reinstalled and this is what I get. Its been quite frustrating trying to figure this out.
Any help would be appreciated. Thank you very much
Swizzin’s support should be able to help troubleshoot what is going on with their installer.
