Sonarr Unable To Locate Show Episodes Using Nyaa.se
Sonarr version (2.0.0.4146):
OS: Windows 7 Professional (x64)
Description of issue: After adding a show succesfully, Sonarr is unable to grab any files for them from Nyaa.se (the only tracker that has them). For example, Re:Zero, Railgun S, Bungo Stray Dogs, Kabaneri Of The Iron Fortress, and Boku No Hero Academy all are imposible to download automatically.
Shows like Archer download as normal.
Is Nyaa.se bugged? Or is there another issue here?
Thanks.
Does Sonarr get results back (check ((debug logs)))?
I think so. It says:
Reports found: 218
Reports grabbed: 0
When I perform a manual search of the episode, it finds the Horriblesubs release just fine. However it seems that these are not eligible to be automatically detected and downloaded.
Also, while I have your attention, why does Sonarr place downloaded video files into my “downloads” folder, not the specified path?
Manual search will tell you why, if there isn’t a reason either it wasn’t seen on RSS or there was an issue grabbing it.
Not sure what you mean, Sonarr will only move files into the series folder or in the case of torrent copy or hardlink it.
I’ll give you an example. I specified that all my files should be placed in c/users/user/videos. However, it places one extra copy of them inside c/users/user/downloads (coincidentally the default download location of uTorrent).
It leaves a copy (or hardlink depending on your settings) there because its still seeding as explained in the ((FAQ)).
I see. Is there a way to make Sonarr remove the torrent from uTorrent after it is complete?
Enabling Remove Completed Downloads should do it once it finishes seeding.
