All maps except not getting the remote path mappings to display the host information below in that row.|
Crossing fingers we can get sonarr/radarr to manage the files.
AND- even if we do not you have been a GREAT help! Very kind and generous.
Restarted Sonarr w/hopes of cleaner log file. Errors are showing in activity, and not necessarily in the Docker/Sonarr logs.
SONAR EVENT LOG *
DOCKER SONARR EVENT LOG
Here are the Docker Sonarr logs in detail…includes a few small setting errors as I was adding indexers.
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/pixelrogue/media3/-data/xxxxx-TBS[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/pixelrogue/media3/-data/xxxxx-xlf[eztv].mkv. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/pixelrogue/media3/-data/xxxxx.web.x264-xlf[eztv].mkv. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Info] RssSyncService: Starting RSS Sync
[Warn] DownloadMonitoringService: Unable to retrieve queue and history items from trans
[v3.0.3.784] NzbDrone.Core.Download.Clients.DownloadClientAuthenticationException: User authentication failed.
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x000da] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:286
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetTorrentStatus (System.Collections.Generic.IEnumerable`1[T] hashStrings, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x000cb] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:188
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetTorrentStatus (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:153
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetTorrents (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:43
at NzbDrone.Core.Download.Clients.Transmission.TransmissionBase.GetItems () [0x00012] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionBase.cs:36
at NzbDrone.Core.Download.TrackedDownloads.DownloadMonitoringService.ProcessClientDownloads (NzbDrone.Core.Download.IDownloadClient downloadClient) [0x0000c] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\TrackedDownloads\DownloadMonitoringService.cs:93
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 10:08:39 PM and 5/4/2020 10:24:08 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 10:08:43 PM and 5/4/2020 10:24:09 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 10:08:39 PM and 5/4/2020 10:24:14 PM UTC. Search may be required.
[Info] DownloadDecisionMaker: Processing 210 releases
[Info] RssSyncService: RSS Sync Completed. Reports found: 210, Reports grabbed: 0
[Warn] SonarrErrorPipeline: Invalid request Validation failed:
-- Host: must be valid Host without http://
[Error] Transmission: Unable to connect to Transmission, please check your settings
[v3.0.3.784] NzbDrone.Core.Download.Clients.DownloadClientUnavailableException: Unable to connect to Transmission, please check your settings ---> System.Net.WebException: DNS Name Resolution Failure: '10.0.1.26.9'
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0015a] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:95
at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookieContainer) [0x00080] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:123
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00008] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:59
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.AuthenticateClient (NzbDrone.Common.Http.HttpRequestBuilder requestBuilder, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings, System.Boolean reauthenticate) [0x0004f] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:219
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x0001f] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:256
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00138] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:308
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetSessionVariables (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:143
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetConfig (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:117
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetClientVersion (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:109
at NzbDrone.Core.Download.Clients.Transmission.Transmission.ValidateVersion () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\Transmission.cs:28
at NzbDrone.Core.Download.Clients.Transmission.TransmissionBase.TestConnection () [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionBase.cs:236
-- Host: Unable to connect
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 10:24:10 PM and 5/4/2020 10:39:38 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 10:24:14 PM and 5/4/2020 10:39:40 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 10:24:10 PM and 5/4/2020 10:39:44 PM UTC. Search may be required.
[Info] Database: Vacuuming Log database
[Info] Database: Log database compressed
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 01-envfile: executing...
[cont-init.d] 01-envfile: exited 0.
[cont-init.d] 10-adduser: executing...
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
Brought to you by linuxserver.io
To support the app dev(s) visit:
Sonarr: https://sonarr.tv/donate
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User uid: 1000
User gid: 1000
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 30-config: executing...
[cont-init.d] 30-config: exited 0.
[cont-init.d] 99-custom-scripts: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-scripts: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[Info] Bootstrap: Starting Sonarr - /app/sonarr/bin/Sonarr.exe - Version 3.0.3.784
[Info] AppFolderInfo: Data directory is being overridden to [/config]
[Info] MigrationLogger: *** Migrating data source=/config/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] MigrationLogger: *** Migrating data source=/config/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] SonarrBootstrapper: Starting Web Server
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 10:39:40 PM and 5/4/2020 10:54:50 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 10:39:40 PM and 5/4/2020 10:54:54 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 10:39:44 PM and 5/4/2020 10:54:56 PM UTC. Search may be required.
[Info] SceneMappingService: Updating Scene mappings
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 10:54:56 PM and 5/4/2020 11:10:20 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 10:54:56 PM and 5/4/2020 11:10:24 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 10:54:50 PM and 5/4/2020 11:10:26 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 11:10:20 PM and 5/4/2020 11:25:50 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 11:10:24 PM and 5/4/2020 11:25:52 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 11:10:26 PM and 5/4/2020 11:25:54 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 11:25:52 PM and 5/4/2020 11:41:21 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 11:25:54 PM and 5/4/2020 11:41:22 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 11:25:54 PM and 5/4/2020 11:41:24 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 11:41:25 PM and 5/4/2020 11:56:51 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 11:41:23 PM and 5/4/2020 11:56:53 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 11:41:25 PM and 5/4/2020 11:56:57 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/4/2020 11:56:53 PM and 5/5/2020 12:12:21 AM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/4/2020 11:56:53 PM and 5/5/2020 12:12:23 AM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/4/2020 11:56:57 PM and 5/5/2020 12:12:27 AM UTC. Search may be required.
Fix your download client connection and test it in sonarr (i.e. ensure your authentication usernames/passwords match)
Also, check your remote path mapping (i.e. settings > download clients > remote path mappings)
Reference my screenshots
Regards
Everything was matching the screen shots when these logs were taken yesterday.
Not getting the Remote Path Mappings content to display (highlighted in previous post)
Logs included other items as well, prior to the Transmission edits recommended.
This Transmission connect is connected and it is working. That said, Sonarr still gives the same error for every file downloaded. So, Sonarr sees the new file, tries to import and do it’s thing but kicks that error.
Indexer error not relevant to the import errors.
Sign in
sonarrlinuxserver/sonarr:preview
RUNNING
Logs
Inspect
Stats
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/xxxxx/media3/-data/xxxxx.web.x264-xlf[eztv].mkv. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/xxxxx/media3/-data/xxxxx-TBS[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/xxxxx/media3/-data/xxxxx-xlf[eztv].mkv. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/5/2020 10:31:56 AM and 5/5/2020 10:47:23 AM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/5/2020 10:32:00 AM and 5/5/2020 10:47:25 AM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/5/2020 10:31:56 AM and 5/5/2020 10:47:27 AM UTC. Search may be required.
[v3.0.3.784] NzbDrone.Core.Download.Clients.DownloadClientUnavailableException: Unable to connect to Transmission, please check your settings ---> System.Net.WebException: DNS Name Resolution Failure: '10.0.1.26.'
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/5/2020 10:47:27 AM and 5/5/2020 11:02:52 AM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/5/2020 10:47:25 AM and 5/5/2020 11:02:54 AM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/5/2020 10:47:25 AM and 5/5/2020 11:02:56 AM UTC. Search may be required.
Stick to bottom
Your host is wrong, I told you it should be host.docker.internal
Regards
Yes yes… had that … it was working… it didn’t change the sonarr error.
Reverted by accident.
Docker - Sonarr Logs are a bit light.
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/pixelrogue/media3/-data/family.guy.s18e17.720p.web.x264-xlf[eztv].mkv. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/pixelrogue/media3/-data/family.guy.s18e17.web.x264-xlf[eztv].mkv. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /Users/pixelrogue/media3/-data/Family.Guy.S18E02.1080p.WEB.x264-TBS[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/5/2020 11:48:58 AM and 5/5/2020 12:04:19 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/5/2020 11:49:02 AM and 5/5/2020 12:04:23 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/5/2020 11:48:58 AM and 5/5/2020 12:04:25 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/5/2020 12:04:19 PM and 5/5/2020 12:19:48 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/5/2020 12:04:25 PM and 5/5/2020 12:19:50 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/5/2020 12:04:25 PM and 5/5/2020 12:19:54 PM UTC. Search may be required.
[Warn] Torznab: Indexer new rss sync didn't cover the period between 5/5/2020 12:19:50 PM and 5/5/2020 12:35:17 PM UTC. Search may be required.
[Warn] Torznab: Indexer t2 rss sync didn't cover the period between 5/5/2020 12:19:50 PM and 5/5/2020 12:35:19 PM UTC. Search may be required.
[Warn] Torznab: Indexer under rss sync didn't cover the period between 5/5/2020 12:19:54 PM and 5/5/2020 12:35:21 PM UTC. Search may be required.
a) Think the paths are identical. Transmission points to the Sonarr container.
Can you elaborate on how to check connecting to sonarr bash?
SONARR MAPPING
TRANSMISSION MAPPING
b) Read/Write offering to everyone on target folder…all related folders.
Not sure how to assign specifically to PUID or PGID ~ and hoping EVERYONE covers it.
AND
At the very least the folder your have set for that series is wrong. Each series needs to have it’s own folder. If you’re using /data/sonarr it should be /data/sonarr/Series Name, no series should be pointed directly to /data/sonarr.
If your download client is directly running on macOS you should use a remote path mapping in Sonarr to remap that remote path to the local path the download client can use. You’ll also want to set the puid/pgid that the docker container is using to match your user though ideally you wouldn’t put anything in your user’s folder you’re just asking for trouble if you’re running things as different users.
At a granular level, yes each series gets its own folder. The example above assigns read/write to everyone, and everything enclosed so those series folders inherit the same. There is one series folder in there now, and its permissions are the same as the one posted for the parent.
Think the remote path in Sonarr is properly connected to Transmission. That part seems to be working fine, and Sonarr spots the new download when it is ready.
PUID/PGID are set to the default 1000 in the config files.
Haven’t messed that. How can you check and would you make the changes in the config file or in docker, or macOS - where would that be done?
I’m talking about your first screenshot in your previous post (the one I replied to), the series path is set to the root folder.
Based on the logs it can’t access the folder, if it’s looking in the correct place relative to the container then it’s fine, but /Users/pixelrogue/media3/... seems wrong.
You want these to match your user on your mac.
First screen shot, the directory names were erased - you would have seen the series fold there… left fragments of the names in the illustration.
Not sure how to identify the PUID/PGID on the Mac, where do I locate that information in order edit the config file to match?
Also had a set up using Users/Share2/…
No matter where the directories resided or permissions assigned the error has remained consistent.
The errors themselves cite the specific file for the failed import. Each time, specific file/direcotry, so to me it seems to match (?)
First result from Google:
The top 2 answers look reasonable.
They show the path from your download client. Did you mount /Users/pixelrogue/ into the Sonarr container at that exact path?
Is your download client in Docker or under macOS directly?
Which volumes did you mount to docker?
I have googled on PUID and PGID, though not as locating them for the Mac.
-reading now-
Thought I had paths from both Sonarr and Transmission there…my bad if missed…nope both are there.
url at present on Sonarr for specific series (series name removed)
That path is the same path mapped through Transmission. Sonarr and Transmission have fond one another both directions.
I see both of them, but I can’t tell whether you’ve mapped the correct things in your container.
I don’t follow, just post the entire container mapping, either from the config file or docker UI.
Again, is your download client in Docker or under macOS directly?
k. have the group and UID…will pick up again tomorrow.
not sure how UID is connected to PUID/PGID
You’d use UID for the PUID and the staff group’s ID for the PGID.
This is great…can’t wait to give it a try. Will take a bit to clear everything out, rebuild and try.
K. Deleted everything…started from scratch. New set up all worked as expected…except… same blasted error of Import Failed.
Here is what I had in terms of the updates to PUID and PGID
ID reveals uid=501 and gid=20(staff). (and groups=20(staff))
So, in the Sonarr config setup I updated the PUID=501 and GUID=20 (did this for all of them).
Set everything else up, downloaded a few files and hit that same Import Error.
Now, this is a different Sonarr setup and it offers a permissions panel (which was not available in other setups).
