Sonarr version (exact version): 4.0.9.2244
Mono version (if Sonarr is not running on Windows): .NET 6.0.13
OS: Docker image (4.0.9.2244-ls256 by linuxserver.io)
I’m trying to configure sonarr and radarr to use transmission as the download client.
My requirements are a bit specific and non-conventional: I only want to use sonarr and radarr to rename, categorize and place downloads in the proper folders. I won’t use any indexer and I’ll add the torrents directly in the client (transmission).
I want to use hardlinks to keep a single copy of the file on disk and be able to keep seeding the torrent after finish.
I’m running sonarr, radarr and transmission in docker and when using the recommended volumes in sonarr (/tv, /downloads), and using the category = tv in the transmission client in sonarr, it works as expected:
- I add a tv show in sonarr
- I add the torrent directly in transmission setting the location as
/downloads/complete/tv - sonarr tracks and detects the download and shows it in the activity queue
- When download finishes, sonarr rename and copy the file to the specified media folder
This works but does not allow to use hardlinks as volumes for downloads (/downloads) and media (/tv) are different.
I changed the volumes to use a single volume in sonarr that groups downloads and media, however it is not working.
I’m following the trash guide for hardlinks (Docker - TRaSH Guides), and this is how the /data folder looks:
data
├── media
│ ├── movies
│ └── tv
└── torrents
├── complete
│ ├── movies
│ └── tv
└── incomplete
Volumes in docker:
sonarr
volumes:
- '/docker/sonarr/config:/config'
- '/data:/data'
transmission
volumes:
- '/docker/transmission/config:/config'
- '/docker/transmission/watch:/watch'
- '/data/torrents:/downloads'
I’m using this docker image: lscr.io/linuxserver/radarr
When starting the docker container for sonarr it complains the /downloads/complete directory does not exist:
You are using docker; download client Transmission places downloads in /downloads/complete but this directory does not appear to exist inside the container. Review your remote path mappings and container volume settings.
So, inside sonarr, I’m configuring the transmission download client with a custom directory (advanced setting) pointing to /data/torrents/complete/tv
When setting a custom download directory, the category option (previously configured as tv) can not be used, so I left the category field empty:
Cannot use Category and Directory
With this config sonarr is not able to detect and track transmission downloads and therefore they do not appear in the activity queue.
Debug log says nothing apart the authentication with transmission was correct.
As far as I know transmission is dumb in the sense it does not support labels or categories as other torrent clients, and the only way the *arr apps use to categorize transmission downloads is with subfolders, however when setting a custom download directory, categories are not configurable.
What is the correct way to set this up? Is it possible to do this with transmission?
